Old 03-04-2013, 12:24 AM   #1
Entroper
Entroper's Avatar
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
Was doing the transmission and diff oils today, when... what is this thing?
It's got threads on the end of it, but it appears to be a GNDN (goes nowhere, does nothing). Anyone know what this is and what purpose it serves?
Entroper is offline   Reply With Quote
Old 03-04-2013, 01:40 AM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Rack & Pinion?
Old 03-04-2013, 03:00 AM   #3
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Looks like an inspection plug
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-04-2013, 03:37 AM   #4
Entroper
Entroper's Avatar
Originally Posted by Sportsguy83 View Post
Rack & Pinion?
That's what it's on, but I'm referring specifically to the threaded circular opening there. Which appears to be closed off about an inch inside.
Old 03-04-2013, 03:40 AM   #5
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
it's for steering rack yoke pre-load adjustment.
JP is offline   Reply With Quote
Old 03-06-2013, 05:11 PM   #6
superpilun
Drives: 1986 MR2
Yup, it basically pushes the rack (the straight part) against the pinion (the gear that turns when you turn the steering wheel) so that there is no play between the gears. There is a spring underneath that thing you're pointing at (technically that's probably the cover, but the adjustment is there). You can tighten it and compress the spring more, and in doing so, you can adjust the force the rack and pinion is pushed together. Too tight and steering becomes too stiff. Too loose and there may be play. It's usually adjusted with an in-lb torque indicator to the specs called out for in the service manual. Feel free to correct me if I'm wrong.
superpilun is offline   Reply With Quote
Old 03-06-2013, 06:59 PM   #7
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Definitely for steering rack pre-load. You'll probably never need or want to touch it.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 03-06-2013, 11:45 PM   #8
Dake
Dake's Avatar
Looks like a left-handed sammoflange.
Dake is offline   Reply With Quote
Old 03-06-2013, 11:48 PM   #9
whataboutbob
AutoX-10/10ths every run
Is that Agent Scully?
Build thread:Here
Old 03-07-2013, 12:52 AM   #10
buckets
buckets's Avatar
Drives: infiniti g37x
im sure agent mulder isnt too far away.
buckets is offline   Reply With Quote
Old 03-11-2013, 11:40 PM   #11
GerryL
Drives: White BRZ
Basically thats the access port needed for manufacturing. Most will never be used again after being put in service, but an adjustment could be done there, and then a new press in cap fitted, if needed.
GerryL is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
New Sponsor intro - Millers ultra low friction oils distributor MillersOilsUS Announcements, Contests, Giveaways 0 12-20-2012 09:41 AM
Hit a deer today. Best thing to do? mark82890 BRZ First-Gen (2012+) — General Topics 33 11-08-2012 09:08 PM
So what is the Big Diff? (pun intended sorry) Erik @ GBox Engine, Exhaust, Transmission 22 10-21-2012 09:21 AM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
