Old 11-12-2018, 10:48 PM   #1
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Crackle pops during wot
As the title says, my problem is when i wot during high rpms, the car will stall and make crackle pop sounds. When it does that, it won't let me go pass that high rpm for example 6000rpm. The needle just keeps bouncing off at 6000. I cant redline to 7600rpm. I am fbo and tuned on e85. I have replaced the clutch switch and same problem occurs. Can it be the injectors? Or something else?
I have changed the spark plugs and heat wrapped the ignition coils.
Besides wot, the car drives just fine.
Dr. BRZ is offline   Reply With Quote
Old 11-12-2018, 10:57 PM   #2
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Is the rev limiter changed ?
mswbrz is offline   Reply With Quote
Old 11-12-2018, 11:03 PM   #3
Dr. BRZ
Dr. BRZ's Avatar
I have it at 7300rpm.
I can't even get to 7000rpm.
Old 11-12-2018, 11:21 PM   #4
86MLR
86MLR's Avatar
Stop doing it and get it on a dyno for some diagnostics.
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
Old 11-13-2018, 12:14 AM   #5
Dr. BRZ
Dr. BRZ's Avatar
It doesn't throw any cel
Old 11-13-2018, 12:16 AM   #6
mswbrz
mswbrz's Avatar
Perhaps try reflashing your tune ?
Old 11-13-2018, 12:47 AM   #7
86MLR
86MLR's Avatar
Maybe a coil, a plug, AFR????
If it's popping on throttle that's a bad thing.
Old 11-13-2018, 01:12 AM   #8
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Could the problem be related to direct injector seals? They're known to make a popping/crackling sound when they fail.
Brz866 is offline   Reply With Quote
The Following 2 Users Say Thank You to Brz866 For This Useful Post:
ermax (11-13-2018), Lantanafrs2 (11-13-2018)
Old 11-13-2018, 11:27 AM   #9
Lantanafrs2
Drives: 2013 frs red
Bad fuel?
Old 11-13-2018, 12:38 PM   #10
Dr. BRZ
Dr. BRZ's Avatar
Thats what i am thinking and hopefully that is the problem cause if not, I'm selling the brz lol
Old 11-13-2018, 12:39 PM   #11
Dr. BRZ
Dr. BRZ's Avatar
Originally Posted by Lantanafrs2 View Post
Bad fuel?
No i dont think, ive been using the same gas station for years. The first time this happened was this year.
Old 11-13-2018, 12:39 PM   #12
Dr. BRZ
Dr. BRZ's Avatar
Tried multiple times and still happens
Old 11-13-2018, 12:47 PM   #13
Brz866
Brz866's Avatar
I would say the tell tale sign is if the crackling/popping is coming from under the hood and not exhaust. 2013s did have a known DI seal issue as well.
Old 11-13-2018, 01:03 PM   #14
Kodename47
Kodename47's Avatar
Drives: UK GT86
Is this recent? Have you changed the tune on the ECU recently? Does it seem like a rev limiter? If it seems like a rev limiter it probably is a rev limiter. It does sound to me like the OFT launch control or EcuTek FFS.
.: Stealth 86 :.
Kodename 47 DJ:
Pops/Crackle Tune do damage to your brz? Jcas Software Tuning 79 01-26-2022 10:29 AM
OFT Pops and Crackle Tune problem V4 niceman Software Tuning 8 09-16-2018 09:27 PM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 11:53 AM
OFT Pops and Crackle Tune just stops working after a while? stig_iv Software Tuning 12 08-21-2018 05:30 PM
