Old 11-01-2018, 01:28 PM   #1
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Smaller Engine Oil Fill Cap
My current stock engine oil fill cap rubs against the sensor wires on my oil cooler sandwich adapter. Wondering if anyone knows of an aftermarket oil cap that has a thinner overall diameter.
I welcome all questions and intolerances about me not wanting to adjust the sandwich plate; it doesn't leak and I don't want it to leak, so I'm choosing the path of least resistance to resolve this issue. Mind you, this is the wiring going to an oil temp sensor that uses one of the 1/8th NPT fitting on the side. Otherwise there'd be no issue.
Thanks in advance!
DarkPira7e is online now   Reply With Quote
Old 11-01-2018, 01:40 PM   #2
Code Monkey
Drives: Subaru BRZ
Just file the cap down a little bit.
Code Monkey is offline   Reply With Quote
Old 11-01-2018, 01:41 PM   #3
Icecreamtruk
Drives: Track preped NA FRS
Did you do anything to your sandwich plate for it not to leak or did you just got lucky? Mine seems to believe its job is coating everything around it in oil. Its pretty at that actually.
Old 11-01-2018, 05:28 PM   #4
DarkPira7e
DarkPira7e's Avatar
I'm considering a Dremel mod if I can't find something nicer to replace it.
I torqued it barely hand tight. I researched a lot and found that the spacer cracks. This happens a lot in water cooled computer systems, (very easy to over tighten a barb) so I just barely made it hand tight and left it. Doing well for about 10k miles!
The Following User Says Thank You to DarkPira7e For This Useful Post:
Icecreamtruk (11-01-2018)
Old 11-01-2018, 05:51 PM   #5
Code Monkey
Drives: Subaru BRZ
The stock cap is very soft, I just used a large file to trim it down.
Old 11-01-2018, 05:55 PM   #6
Icecreamtruk
Ohhhhh that makes soo much sense. Well I think I have a craqued spacer then. Will check it out when doing maintenance before next season. Thanks for the info.
Old 11-01-2018, 06:37 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
What brand adapter?
Old 11-01-2018, 07:03 PM   #8
Icecreamtruk
What brand adapter?
Mishimoto, exactly the same as in the picture.
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Ultramaroon (11-02-2018)
Old 11-02-2018, 01:28 AM   #9
Ultramaroon
not playing cards
Ah, then I'm no help. Hope it's an easy fix.
Icecreamtruk (11-02-2018)
Old 11-03-2018, 05:57 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I appreciate the posts suggesting a DIY approach. However, for those who don't want do go that direction or would like to incorporate a subtle aesthetic/visual engine bay mod into this solution, it would be great to have a list of aftermarket oil caps with known good fitment with aftermarket oil coolers.
I have the same issue with my OEM cap and I would love to replace it with an aftermarket cap that easily clears the sandwich plate fittings!
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
DarkPira7e (11-03-2018), Ultramaroon (11-03-2018)
Old 11-03-2018, 06:28 PM   #11
Clipdat
Proud of BOXER
Clipdat's Avatar
I haven't checked aftermarket oil caps for a while, but wow there is quite a selection of them on ft86speedfactory! Some tempting options for sure!
Without knowing the exact outer diameter of the OEM cap and then comparing that measurement value to an aftermarket cap, it's difficult to know what would fit or not.
Hopefully people running aftermarket caps with oil coolers see this thread and can let us know what caps have a good fit.
I'm old and lazy
Old 11-03-2018, 06:53 PM   #12
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
If you cant find one, pay someone to either 3d print or CNC one.
Old 11-04-2018, 09:40 PM   #13
Hawk77FT
Drives: GTS 86
Ermm, why no rotate the plate/adapter few mm? or rotate it full 90 degrees counterclockwise ?
Hawk77FT is offline   Reply With Quote
Old 11-04-2018, 10:40 PM   #14
FastWhite
Drives: Subaru BRZ Limited M/T
Try RacerX. I had a STI oil cap that rubbed on the adapter. They have a smaller diameter one on their website.
FastWhite is offline   Reply With Quote
Free radiator, fill neck, and engine cover dstrout Mid-Atlantic 1 06-05-2018 04:50 PM
Is it necessary to pre-fill the oil filter? lupindub Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 27 06-07-2016 04:58 PM
Fill and paint? or PDR... rhythmM Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-12-2014 10:36 PM
First fill-up... mit_peid Scion FR-S / Toyota 86 GT86 General Forum 3 01-20-2013 06:46 PM
Smaller next-gen Mazda MX-5....YES Mouse Other Vehicles & General Automotive Discussions 172 12-06-2011 02:21 AM
