Old 10-29-2018, 03:24 PM   #1
GrandSport
GrandSport's Avatar
Drives: 13 Viper; 14 BRZ; 90 Miata; 18 AMG
Engine oil cooler install/mounting
Can someone give me some pointers/advice about using a universal kit vs. a kit with cut to length hoses, brackets, yet? Normally, I don't mind buying away a headache, but $350 for a bracket and hoses is pushing it.
Is it fairly easy to find a place to mount a heat exchanger? Also, is it fairly easy to tap into the hoses coming out of the factory in tank heat changer or do I basically need the sandwich plates?
GrandSport is offline   Reply With Quote
Old 10-29-2018, 03:44 PM   #2
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
I bought a Perrin kit, but ended up mounting it myself, since the Perrin kit doesn't include mounting for the crash beam. I just used a couple of T-brackets, some self-tapping sheet metal fasteners and metal spacers. It ended up working out well enough.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
GrandSport (10-29-2018)
Old 10-29-2018, 03:59 PM   #3
norcalpb
norcalpb's Avatar
Yes, there are holes in the floor panel in front of the radiator where you can mount the cooler with no drilling required.
You are going to need an aftermarket sandwich plate as our cars don't come with one from the factory. I believe you'll also need a spacer that the sandwich plate sits on top of.
If you don't mind buying away a headache, I think the Racer-X unit is great at only $600 which comes with a Setrab 613 cooler. http://racerxfabrication.com/frs-brz...oil-cooler-kit
The Following User Says Thank You to norcalpb For This Useful Post:
Old 10-29-2018, 04:17 PM   #4
Code Monkey
Drives: Subaru BRZ
^ This, but get the 619 and top mount location.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Old 10-29-2018, 04:27 PM   #5
Just get the Jackson Racing, which includes a sandwich plate that has bungs for additional sensors (e.g. pressure), and includes a 915 core.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
GrandSport (10-29-2018), Shark_Bait88 (10-29-2018), Tristor (10-29-2018), ZionsWrath (10-29-2018)
Old 10-29-2018, 04:31 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
My advice is don't mount to the plastic
I enjoyed my jackson racing NA cooler which mounted to the stock crash bar. It even survived a front end bump without a dent
The Following User Says Thank You to ZionsWrath For This Useful Post:
Old 10-29-2018, 04:38 PM   #7
GrandSport
GrandSport's Avatar
That thing isn't cheap! I've got to get some camber plates and hood vents too.
I don't have nearly as much experience as you with these cars, but I have ot imagine that even a small EOC would be enough for a mostly stock engine. It's not like it's boosted or anything.
Old 10-29-2018, 04:42 PM   #8
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Just get the Jackson Racing one, it works exceptionally well and the installation was relatively painless considering. The sandwich plate and hoses it comes with is extremely well put together too. I'd trust it over anything I'd cobble together myself off Summit Racing anyway, which is why I decided to buy my headache away.
Tristor is offline   Reply With Quote
Old 10-29-2018, 05:45 PM   #9
This is universal to any engine, but oil temps have zero relation to the actual output of the engine. Whether its stock, or supercharged with 800hp, oil temps remain about the same.
Engine RPMs will dictate oil temps, and as you've seen, this engine does rev higher than most LS/LT.
A V8 does put more stress on the oil temps, because you have more surface area being swept/cooled by the V8, essentially double the amount of surfaces, but that's why a lot of vettes have heat issues when driven hard, showroom stock!
Even with the 915 core, a fast driver pushing the car hard, will be at about the upper limit of what I'd be comfortable with in terms of oil temperatures.
Old 10-29-2018, 06:06 PM   #10
GrandSport
GrandSport's Avatar
I guess I'd just respectfully disagree here. Engine rpm is obviously a big factor- friction is a big contributor heat, but so is power output. Bigger engines tend to have more oil, more cooling (both external and through the block). Boosted engines really crank up oil temps too (plus, the intercooler).
If you drive down the highway at 55mph at 5k rpm for 20 min, your oil won't like it.
If you put a giant sail on your car and were WOT at 55mph for 20 min, you'd probably be buying a new engine.
Engine load is literally part of the calculations we did to determine appropriate heat changer sizes for every fluid.
As far as Corvettes- there are a number of reasons they have such high engine oil temps. Air inlet size, engine heat exchanger size, etc, etc. It's not just the oil either. Often, the coolant overheats before the engine oil. On the Z06 it's literally every fluid. That thing, especially pre 2017 with an auto, is an embarrassment and a disaster. A guy at the track with me was running neck and neck with me in a stingray overheating his 2018 (so much upgraded cooling) manual Z06. Complete joke.
Out of curiosity, what is your limit for comfort for engine oil temps?
2014 BRZ: WRL Build (GP2) MCS, AP, Motec, race wiring harness, blah blah blah
2014 FRS: Similar WRL Build. Back up / parts / practice race car.
2013 Viper GTS : Tractive Coilovers, ACR sway bars, aero, carbon, exhaust, etc.
1999 NB Spec Miata: 1.8 w/ all the goodies.
2022 CT5 Blackwing: Stock.
Old 10-29-2018, 07:22 PM   #11
Remember, the engine isn't oil cooled, and in particular, look at the relative temperature of each friction surface!
I generally will be careful at 250F, and would do a full stop at 260F.
My turbo car sits at about 235F max.
Old 10-29-2018, 07:34 PM   #12
GrandSport
GrandSport's Avatar
It's not "oil cooled" but like it or not, more heat will transfer to it when you make more power. Also, there will be more heat from friction.
Maybe it's my cars, but I'm fine with engine oil temps below 275. 290 I stop (though, my GS never sees that). I have friends that run 300 all day (and some race teams do too).
Old 10-30-2018, 03:05 AM   #13
Those are temps I'm comfortable with in other cars, but not this one.
Do your other cars run 0W20?
I would hope more heat is transferred *into the coolant* with more power. Friction is generated by surface area and velocity, with very low relation to actual output. Think about how much displacement a LS/LT has, vs displacement, vs coolant area, vs that of a FA20.
Another way to think of it, is that the LS/LT makes more heat due to the pure amount of area involved, with zero relation to the actual output.
Here's a great way to verify output, vs heat. Try cruising in your vette at 6000 rpm, at 70 mph. It takes very little output to maintain 70mph in the vette right? Being generous, maybe 20hp at most. Yet, that oil temp keeps creeping up...
Old 10-30-2018, 10:46 AM   #14
To add to this the majority of the heat created by an engine is from combustion not friction. The larger the combustion chamber and the more fuel that is burned the greater the heat. If you are getting the bulk of your engine heat through friction you already have a huge lubrication issue!
strat61caster (10-30-2018)
My Racer X / Setrab oil cooler install snuff58 Engine, Exhaust, Transmission 35 05-02-2019 10:06 PM
DIY oil cooler mounting. CoolHandMoss Engine, Exhaust, Transmission 11 02-09-2018 10:39 AM
Oil Cooler install in the GTA.. Skurj CANADA 53 06-24-2015 02:51 AM
Another Oil Cooler Mounting Option FastJew Tracking / Autocross / HPDE / Drifting 12 05-18-2014 09:13 PM
Help! Oil Cooler Install brillo Tracking / Autocross / HPDE / Drifting 13 07-17-2013 04:55 PM
