Drives: 2014 Subaru BRZ Limited MTblue
My Racer X / Setrab oil cooler install
My parts:
Setrab 9-series STD 15.94"x4.53" pn: 50-915-7612 Setrab brackets pn: 23-9002 Setrab adapters AN10 - M22 pn: 22-M22AN10-SE Racer X Fabrication thermostatic sandwich plate, no finish pn: 02004X-AN-RAW fitting at plate: Summit Racing AN10 o-ring to AN10 flare adapter pn: SUM-220164N hose: 2 x 3' AN10 black nylon hose, Summit Racing pn: SUM-240003B hose ends: 3 x Russell Endura AN10 90degree, nickel finish, pn: 610181 1 x Russell Endura AN10 45 degree pn: 610111 some parts pictured:
More to come . . . . . out of time, just now!!!
Please, NO comments until I have finished!!!! |
Thanks
First
Well, I am having a hard time getting my images I stored in imgur to show.
More patience, please. (maybe my efforts to share are resulting in too much trouble to continue)(we'll see....) |
Here is the 90 degree hose end:
I chose the Setrab 9 series cooler. I did not want to mount it on the plastic shelf behind the bumper. I wanted securely use the manufacturer's brackets, and mounted it on the back of the collision bar. I had a friend make these brackets from aluminum:
Bumper removed:
Collision bar removed:
Showing the spacing for the mounting holes using the Setrab bracket as a guide:
#10 |
Here is a shot of the collision bar with all for holes drilled to accept rivet nuts:
#11 |
I sprayed some paint in each hole edge to help deter corrosion. Here is one rivet nut installed, followed by all 4.
#12 |
#13 |
Here is the Setrab w/ brackets mounted to the collision bar with my custom-made brackets.
#14 |
and bar mounted:
| FS: Setrab 19 Row Oil Cooler | byun | Engine, Exhaust, Bolt-Ons | 24 | 10-16-2015 02:07 PM |
| *BRZ Part Out* Setrab oil cooler kit | xDanger_208x | Engine, Exhaust, Bolt-Ons | 12 | 04-07-2015 08:50 AM |
| FS: Setrab oil cooler. Vortech V3 oil. | MyRx | Engine, Exhaust, Bolt-Ons | 7 | 03-20-2015 01:23 PM |
| Setrab/Perrin oil cooler | jack43 | Engine, Exhaust, Bolt-Ons | 2 | 11-24-2014 01:59 AM |
| Setrab 10 Row Oil Cooler *SOLD* | Captain Snooze | Australia Classifieds | 0 | 07-08-2013 06:18 AM |
