#1819
Drives: Lightning Red Subaru BRZ
Fishtailing after installing SPC LCA. Looking for causes.
I installed SPC LCA last night and while driving home from the garage my car fishtailed violently at low speeds. I took it back to adjust the camber on the LCA but the fishtailing still occurred but was slightly more controllable. Controllable enough to limp it home.
My question is if this is just an issue with my car needing an alignment or something else is causing it? I checked the lugs and the bolts when I got home and they were fine. I plan on getting the car aligned and having fresh tires put on. Hopefully that resolves the problem but if not I don't think I can drive the car anymore in this condition. |
Drives: C5, GT-86, '24 Colorado TrailBoss
Toe is probably way off. Yes after installing a suspension component with adjustments you want an align. Im going to sound like a DiK but that should be common sense
| The Following 11 Users Say Thank You to SuperTom For This Useful Post: | bhmax (10-26-2018), justint5387 (10-25-2018), kch (10-25-2018), Leonardo (10-25-2018), mrha (10-25-2018), norcalpb (10-26-2018), olsonpg (10-25-2018), strat61caster (10-25-2018), Summerwolf (10-25-2018), Tristor (10-25-2018), Ultramaroon (10-26-2018) |
Drives: BRZ. R34 GT-T
Like supertom said, its the toe. Same thing happened to me.
/ SARD / ENKEI / GREDDY / RACESENG / CUSCO / PERRIN / KW / POWERED BY MAX / SPARCO / STOPTECH / BREMBO / ROCKET BUNNY / FULL-RACE twin scroll / OS GIKEN / WHITELINE
| The Following User Says Thank You to olsonpg For This Useful Post: | mrha (10-25-2018) |
Panda Trueno
Drives: No twin now.
Probably need an alignment. You have messed with the suspension geometry.....
Drives: 2013 FR-S Series 10
When i replaced mine, even trying to get it same as stock arm and eyeballing it, i still had a whole degree (inch?) of toe in according to my alignment report. I did make sure not to get toed out, as that gives you that crazy unstable feeling OP refers to.
https://www.instructables.com/id/DIY...gnment-Toe-in/
1st result in googles, lots of others available including videos. Simple and quick
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| FRS fishtailing video | Zhangy | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 01-12-2017 11:21 AM |
| Need help installing my avo turbo kit | Astroboy | Forced Induction | 80 | 04-11-2014 10:03 AM |
| Need help installing some coils | tysoNgwaNg | Northern California | 14 | 03-24-2014 08:20 PM |
| Installing the q300 myself | hunter3232792 | Engine, Exhaust, Transmission | 16 | 12-08-2013 09:24 AM |
| need help installing this | chenshuo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-14-2013 01:17 PM |
