Old 10-18-2018, 12:12 PM   #1
scottryan
Financial Distress
scottryan's Avatar
Drives: 2017 GT86 325WHP
Uneven coilovers (Yonaka Spec 2)
So I'm still learning more and more about cars, and I noticed while jacking my car up from the front that when the car's raised, one wheel falls at least 3" lower than the other, what should I be looking for to fix that? The same issue is found at the rear as well, one side sits a bit lower than the other when raised. In addition, how would I go about softening the suspension after evening these out? I don't run very low and just want to dampen some of those aggressive bumps while driving. This is definitely a beginner question, so forgive me for that, still learning.
Coilovers: Yonaka Spec 2
scottryan is offline   Reply With Quote
Old 10-18-2018, 12:47 PM   #2
redlined600
redlined600's Avatar
Drives: Fr-s
You'll have to figure out if the droop travel is being limited by the coilovers or more likely the bushings. Additionally the swaybar could be limiting travel if the endlinks are not adjusted correctly.
Finally it appears as though the coilovers are preload and height adjustable. Do you have the preload set correctly? It's possible those settings are messed up.
Does the car sit correctly on the ground?
Old 10-18-2018, 03:30 PM   #3
scottryan
Financial Distress
scottryan's Avatar
The car sits perfectly on the ground, but when raised the passenger side wheel hangs lower than the driver's side. It most likely is the coilovers, I could have adjusted the height on one, and adjusted the pre-load on the other without noticing.. thanks for the help dude!
Pure red FRS, how it looks on yonaka coilovers and XXR wheels nhuyvan1106 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 11-11-2016 03:33 AM
YONAKA Coilovers Installed/reviewed Shit Luck Suspension | Chassis | Brakes -- Sponsored by 949 Racing 32 10-04-2016 01:48 PM
Yonaka Motorsports Coilovers *Chicagoland* $600 OBO taylorbosse Brakes, Suspension, Chassis 5 08-06-2014 09:28 PM
Yonaka adjustable coilovers Shit Luck Brakes, Suspension, Chassis 3 11-24-2013 05:42 PM
