Old 10-16-2018, 12:39 AM   #1
Darth
Drives: 2016 White Pearl Brz
DIY Starlight Headliner
Any guides or tips and tricks out there on doing rgb starlight headliner ?
Darth is offline   Reply With Quote
Old 10-16-2018, 05:05 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the Forum!
Patience. Don't bend the headliner when you take it out. Removing the passenger seat makes it easier. I assume that you are talking about one of these DIY kits. And not the premade kit that is $3000.00.
https://www.ebay.com/itm/10W-RGBW-Ca...juj:rk:15:pf:0
Make your self a clean work area.
Take your headliner out.
Get some fabric glue and a soldiering iron.
Feed each fiber (yes, one at a time) through the headliner from the back. Then use the soldiering iron to flatten the tip carefully. The slightly flattened "head" of the fiber now will be harder to pull back through (which you do not want), makes the "star" look a little brighter, and is better for gluing. Pull the fiber back to the fabric and dab one drop of glue on it. Either on the front, or the back. It depends on how the glue looks on the fabric. The back is probably best looking, though more time consuming.
Make your pattern clustery, like the night time sky. If it is too even it won't look right.
This is a time consuming process, but the end result (if you had patience and a little skill) should look awesome!
I work with LEDs. And, have made fiber optic and LED lighted: t-shirts, ball caps, posters, and a few other random things using this method.
Good luck!
I LIKE TIRES!
Old 10-17-2018, 10:47 PM   #3
Darth
Any possible installation videos available out there ? All the videos I see on
YouTube aren’t too detailed on how to tap them through the headliner and secure them
Old 10-20-2018, 09:39 PM   #4
Darth
No videos out there ?
Old 10-22-2018, 04:54 PM   #5
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Took me all of 3 seconds to find a how to......
Removing Headliner? l0aded DIY (Do-It-Yourself) Guides 15 05-04-2016 01:24 PM
Headliner Removal Guide FRSPacNW DIY (Do-It-Yourself) Guides 4 09-05-2014 03:49 PM
WTB Headliner for FRS? Shock_r Canada Classifieds 4 11-26-2013 04:48 PM
FS: FRS (oem) Headliner NRG x FRS Interior Parts (Incl. Lighting) 1 11-28-2012 12:27 AM
