Old 08-12-2013, 08:50 PM   #1
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Removing Headliner?
Has anyone done this before? I want to put some deadening/insulation (3m Thinsulate Accoustic) up there to keep out some sound and heat and get rid of a rattle but just a little worried about how to do it. I have a fair amount of experience taking the car apart but just haven't touched the roof yet. From what I understand I will need to take off the visors/dome light and possibly the quarter panels to remove the headliner.
l0aded is offline   Reply With Quote
Old 08-12-2013, 09:42 PM   #2
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I'd like to know this as well.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 08-13-2013, 03:28 PM   #3
l0aded
Addicted
l0aded's Avatar
Doesn't seem like many people have done this route. When I have the chance I'll give it a shot and post pics.
Old 08-13-2013, 03:32 PM   #4
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Just curious... Are you sure rattle is in the headliner? I had a rattle I couldn't locate and was my homelink rearview mirror. The screws were stripped by whoever installed it at the port. (Speaking of which my dealer hasn't called me and they should have the new bracket by now dang it!)
Thanks!
Subaru STI :
Old 08-13-2013, 10:46 PM   #5
Tim_Asphalt_FRS
Is it fast? No.
I just want it to not be so loud when it rains.
Old 08-14-2013, 01:34 AM   #6
Gen
Drives: Scion FR-S
Basically anything that touches the headliner needs to be removed...A pillars, B pillars, C pillars, and visors. From there, it's just a couple of plastic snaps. Pretty easy removal compared to most cars.
Gen is offline   Reply With Quote
The Following User Says Thank You to Gen For This Useful Post:
Tim_Asphalt_FRS (08-14-2013)
Old 08-14-2013, 01:12 PM   #7
infinite012
Drives: 13 DGM BRZ Ltd
3 plastic clips in the rear up near the back window (pop off with flat head), pull the C pillars (pull), remove the sun visors (2 screws each, optional if you have lights in the visors: unplug), remove sun visor retaining clips (use flat head lightly remove), remove the dome light (flat head, unplug), remove bluetooth mic (flat head, unplug), pop the center front of the headliner in front of the dome light.
After you get all that removed, the headliner will sag down. Use the space behind the C pillar and in front of the A pillar to shimmy the headliner out. You do not need to remove B pillars.
infinite012 is offline   Reply With Quote
The Following 5 Users Say Thank You to infinite012 For This Useful Post:
BabaYaga (08-17-2017), Bonburner (12-16-2017), mike_ekim1024 (09-09-2013), Tim_Asphalt_FRS (08-14-2013), wdninja (11-19-2013)
Old 08-24-2013, 11:27 PM   #8
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Someone should do a picture version of this.
ApolloSki is offline   Reply With Quote
Old 08-26-2013, 09:15 AM   #9
infinite012
There's really no room to get pictures.... It's pretty straight forward, though. Once you start ripping into it, you'll see how everything comes out and goes back together.
Old 08-26-2013, 10:05 AM   #10
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
pictures please!
448hpsti is offline   Reply With Quote
Old 06-30-2014, 11:43 PM   #11
AzFranz
Az to Nm to Az
AzFranz's Avatar
I am getting ready to do Dynamat extreme and there absorb mat and heat refelection on my entire car. I will do a pictorial.
Patience though as it was 113 here today and isn't going to let up.
It's a sleeper...I launch, it feels like it's asleep.
AzFranz is offline   Reply With Quote
Old 07-01-2014, 05:18 PM   #12
nadbrz
Learnin a little everyday
Drives: '13 Crystal Black Silica BRZ
It's pretty straight forward and evident, once you start it you will know your way. I did it on mine. Added dynamat and 3M thinsulate to it. My car went so quite when it rains.
nadbrz is offline   Reply With Quote
Old 01-27-2016, 10:35 AM   #13
sam69
Drives: GT 86
Digging an old thread up and was wondering how much space there is between the hood liner and the roof ?
Would one be able to use 10mm closed cell stick on foam or would 6mm be a better option .
sam69 is offline   Reply With Quote
Old 03-28-2016, 08:49 AM   #14
ZZT86
ZZT86's Avatar
Drives: BR86
I shoved deadener & then some 12mm acoustic foam liner in there & there's plenty of room for all this . . . much more solid & quieter now.
ZZT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to ZZT86 For This Useful Post:
BabaYaga (08-17-2017), sam69 (03-29-2016)
Anyone notice vibration from headliner? BRZnut Issues | Warranty | Recalls / TSB 22 01-16-2018 10:11 PM
sunglass holder - headliner Alabang 86 Cosmetic Modification (Interior/Exterior/Lighting) 9 07-05-2013 10:26 AM
Wtb rear deck / headliner jshadeck Exterior Parts (Aero, Lighting, Etc.) 0 02-03-2013 09:31 PM
FS: FRS (oem) Headliner NRG x FRS Interior Parts (Incl. Lighting) 1 11-28-2012 01:27 AM
Power source in headliner? BoostedWrbBrz Electronics | Audio | NAV | Infotainment 2 11-10-2012 05:36 PM
