Old 10-15-2018, 03:23 PM   #1
MagicMexican
Drives: 2013 BRZ Premium
Heater Knob Not Working
A few months ago my climate control knob started getting 'stiff'. If I went from cold to hot, it would freeze up, then I would have to back it off a bit back to lukewarm, then I could go to full hot.
Then the knob stopped working yesterday, there was no resistance to it, I could just spin from hot to cold but the air was still lukewarm.
I took it apart and found that there's two wires on it that are supposed to go in a groove in the knob and they had fallen out. I put them back in correctly, and thought it was fixed, but it fell out again later on that day.
Has anyone had this happen, is this a known issue or is there a fix...?
I did some searching and found that the part is Subaru 72331CA030, it's only $25 but I'm not sure how far back it goes into the dash, I'd rather not have to tear it part even further, especially if it's just going to happen again.
MagicMexican is offline   Reply With Quote
Old 10-15-2018, 05:44 PM   #2
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Control cables are usually accessible behind the glove box or above the gas pedal. Shouldn't be a big deal.
Old 01-04-2020, 12:11 PM   #3
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
My 2013 Scion FRS Ac temperature control did not function so I dismantle the AC control panel and found that the piano wire had came off track on that plastic spool. I had to anchor that brass end and put the wire back in. Then I noticed the cable where it is anchored down was not secured so I cut a plastic hotel key and tape it to the cable where it attaches to stabilize it and keep it straight so it would be less resistance. I also tape up the spool that the piano wire will not pop out again. There is a youtube video on a 2009 Corolla Ac repair. https://www.bing.com/videos/search?q...9D70&FORM=VIRE
speedy racer is offline   Reply With Quote
Old 06-25-2022, 06:07 PM   #4
Crispy Albino
Drives: Hot Lava FRS w/ Five-AD aero kit
I had the exact same thing happen to mine. I just bought a new instrument panel off ebay and I’m about to install it now.
Crispy Albino is offline   Reply With Quote
Old 06-25-2022, 07:44 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
In my first year of ownership I noticed, and commented here that both temp and direction controls became noticeably stiffer with the blower running. I developed a habit of shutting off the blower before making adjustments.
This decreases internal wear on the solid control cables and links.
Old 06-26-2022, 02:33 AM   #6
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
Dust also collects in the knob at the control face as well, which can cause them to bind. A little disassembly/compressed air/spray grease can help loosen them
EndlessAzure is offline   Reply With Quote
Old 03-18-2025, 10:52 PM   #7
speedy racer
I’m in the process of replacing the temperature cable, it’s easily accessible, just drop the glove box. The cable is only $50 and just snaps in place.
Old 03-20-2025, 12:00 AM   #8
EndlessAzure
Wheels for Brains
how did you get the gear off without breaking anything
Old 03-25-2025, 05:36 PM   #9
speedy racer
Just snaps off, I used a little pick tool, I just replaced it today. Turn on your engine, turn the dial to highest heat, snap the big part in, then turn the temperature knob to maximum heat and snap the smaller white part in, it should be good to go. Stealership would probably charge at least 1k! Don’t turn the temperature knob while the bower is on, it puts more resistance on the cable, my cable was falling apart on both wheels.
Old 03-26-2025, 11:51 AM   #10
speedy racer
https://gt86stuff.onrender.com/t3Por..._rm_index.html
How do I run my heater lines? Clash0901 Engine Swaps 42 11-06-2018 11:42 PM
Solar shift knob not working jcb476 Scion FR-S / Toyota 86 GT86 General Forum 3 08-24-2018 10:12 PM
Air ventilation knob not working tazz786 Issues | Warranty | Recalls / TSB 7 12-17-2016 10:28 PM
mirror adjustment knob not working Mikegraves777 Issues | Warranty | Recalls / TSB 6 09-19-2013 09:17 PM
Is there an OEM block heater? KevinBRZ BRZ First-Gen (2012+) — General Topics 1 08-22-2013 01:18 PM
