Old 11-25-2016, 11:16 PM   #1
tazz786
Drives: 2015 scion FR-S
Exclamation Air ventilation knob not working
Out of nowhere my knob will not turn farther than where it is at, anybody know what the issue can be?
tazz786 is offline   Reply With Quote
Old 11-26-2016, 03:21 AM   #2
humfrz
Have you been messing around with something under the dash, like the head unit....??
My guess is that a rod/wire inside one of the cables is kinked.
If so, fixing it would be easy ...... getting to it to fix it ..... not so easy......
humfrz
Old 11-26-2016, 03:32 AM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Either that or the door to the upper vents is jammed open. That's the next function to toggle.
Old 11-26-2016, 01:01 PM   #4
tazz786
humfrz
i literally did not touch anything. just got in my car and tried changing it over and it wouldnt budge. I took my car in for a wash but i dont know how that could have done anything.
Old 11-26-2016, 01:28 PM   #5
Ultramaroon
not playing cards
It happens. Unfortunately if it is the diverter door itself it will be a massive PITA to fix. Usually the entire center console needs to be disassembled to get in there.
Old 12-17-2016, 08:46 PM   #6
tazz786
i Ended up fixing it. SO what happened was the wire from the GPS module became wrapped around the actuator. I removed the aftermatket pioneer head unit and fixed it up.
Old 12-17-2016, 09:59 PM   #7
humfrz
Well, tazz786, good you got your car's knob working.
....... now, that's fer messen wich it and not fessing up.....
humfrz
Old 12-17-2016, 10:28 PM   #8
Ultramaroon
not playing cards
The cool thing is you will never forget the circumstances that caused the failure.
Kudos!
Laile Under Panel ventilation radroach Scion FR-S / Toyota 86 GT86 General Forum 33 03-20-2020 10:31 AM
ft: stainless steel wc lathe werks knob for stock brz knob lp87 Interior Parts (Incl. Lighting) 17 02-12-2015 03:26 PM
FS Raceseng 86 AT Shift Knob and Cusco Red SPin Turn Knob Unidentified Interior Parts (Incl. Lighting) 2 01-06-2014 09:55 PM
mirror adjustment knob not working Mikegraves777 Issues | Warranty | Recalls / TSB 6 09-19-2013 09:17 PM
Cusco Spin Turn Knob (Drift Knob) gatorbushmen Scion FR-S / Toyota 86 GT86 General Forum 8 04-29-2013 11:14 PM
