Old 09-13-2018, 09:05 AM   #1
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
How do I run my heater lines?
UPDATE: check page 3 to see my final solution.
I have no idea what i'm going to do for heat. I cut back the lines as everybody mentioned doing. But now i'm sitting here with thes 1" long heater core pipes out of the firewall and no clue how to get a hose to stay on them without slipping off.
Anybody have any suggestions? I would really love to have heat for spring and fall weather.
Thanks
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Old 09-13-2018, 10:36 AM   #2
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Thanks
Take a heavy duty wire crimper, cut and grind it down so that half fits inside of the piping, and it becomes a bead roller essentially.
Like so:
I'll try to photograph mine tonight, I wont need them after this weekend if you want them.
spitsnaugle is offline   Reply With Quote
The Following 2 Users Say Thank You to spitsnaugle For This Useful Post:
Leonardo (09-13-2018), venturaII (09-13-2018)
Old 09-13-2018, 10:40 AM   #3
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I've never had to do that but would worm clamps work?
Current DD: M235i
8RZ is offline   Reply With Quote
Old 09-13-2018, 01:44 PM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Similar to what was done here:
http://www.ft86club.com/forums/showp...&postcount=283
All you need is enough of a bead to keep the hose from slipping off when clamped. I don't know what the system pressure is, but it's almost certainly under 20psi, so it doesn't have to be bombproof...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 09-13-2018, 04:23 PM   #5
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
The crimp idea is decent BUT i really don't want to take this engine back out just for 2 heater core pipes.
A worm clamp may work but I was told eventually it would pop off if there's no bead, so I'm naturally worried.
I also thought about just flaring the ends out with a pipe flare, but even for that, the engine needs to come out
Old 09-13-2018, 04:39 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I'm not 100% sure this is how things work, but here is my idea. Remove your heater core. It looks like it removes/installs from the cabin, not the engine bay. Flange the ends to your spec and re-install. Taking the dash out is easier than the engine.
I LIKE TIRES!
Old 09-13-2018, 05:01 PM   #7
gtpvette
Drives: 2015 FRS - FFR GTM
Maybe if you could get a partial bead with a crimper or at least a few bumps it'd be enough to keep a hose on. I've also seen a few guys use the gates Powergrip heat shrink clamps.
[ame]https://www.youtube.com/watch?v=4O91YqHbp8c[/ame]
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Zer0 (09-13-2018)
Old 09-13-2018, 05:18 PM   #8
venturaII
venturaII's Avatar
Then why not try clamping it on first and just running it? Worst case scenario is it comes off and you get a tow home. Just make sure your first drives are around town. At that point, you look into solutions requiring more work. It's not like you won't know that the hose came off...the cloud of steam and antifreeze behind you will be pretty obvious..
The Following User Says Thank You to venturaII For This Useful Post:
humfrz (09-13-2018)
Old 09-13-2018, 08:06 PM   #9
Zer0
Drives: 2015 frs
They make bulkhead plates that they use to reroute the lines to a different location. Pull the HVAC box under the dash, decide where you want them in the engine compartment mount the bulkhead and run your lines.
https://www.googleadservices.com/pag...xoCfUIQAvD_BwE
Zer0 is offline   Reply With Quote
Old 09-13-2018, 08:17 PM   #10
humfrz
I agree with this plan. Just clean up the heater core pipes with emery cloth real good, make sure the hose ends are "fresh" ly cut and fit snug.
Use a new worm clamp, positioned so as you can get a good grip on the screw. Tighten it down as hard as the screw will allow.
Fire er up and get the engine good and hot - if it holds first off, there is a good chance it will hold till the rubber hoses rot away.
humfrz for Bubba
Old 09-13-2018, 09:21 PM   #11
Zer0
Drives: 2015 frs
Whatever you do make sure it's secure. If it blows off and you don't notice your going to overheat, and possibly loose the head gasket. I would put a bead on the tube to secure it with a clamp. Hoses don't grip straight tube well. That's why they put a bead on them from the factory. Just my 2 cents you might get lucky without a bead on the tube. I wouldn't gamble on it.
Old 09-13-2018, 11:01 PM   #12
ILLSMOQ
Drives: 2017 WR BLUE BRZ
https://www.summitracing.com/parts/e...0erl/overview/
I used those and AN’d the whole thing
ILLSMOQ is offline   Reply With Quote
The Following User Says Thank You to ILLSMOQ For This Useful Post:
Zer0 (09-13-2018)
Old 09-14-2018, 08:45 AM   #13
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I think I'm going to be pulling the dash to get this thing sorted properly. I don't want any leaks or hoses bursting off if it can be avoided.
Old 09-14-2018, 11:05 AM   #14
spitsnaugle
The AN fitting route is very solid/proper, and way easier than pulling a dash. I'm now back tracking and going that route instead of my fix. Thanks for the suggestion ILLSMOQ
Fuel Lines: OEM Hard lines into LS fuel rail Sportsguy83 Engine Swaps 22 06-29-2020 01:18 PM
Air flow for heater/AC sebgrami Scion FR-S / Toyota 86 GT86 General Forum 2 02-04-2017 01:17 AM
Heater hose Vic_RSA AFRICA 2 09-28-2016 05:43 AM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 06:56 PM
Is there an OEM block heater? KevinBRZ BRZ First-Gen (2012+) — General Topics 1 08-22-2013 02:18 PM
