Old 10-09-2018, 02:20 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Reverting to stock tune on Ecutek
Not that I’m going to do it but just curious to find out how this gets done with Ecutek. I know with OFT it’s simply just reprogram the stock ROM back to the ECU.
stlgrym3 is offline   Reply With Quote
Old 10-09-2018, 02:43 PM   #2
Fred E
Drives: WRB BRZ
The Ecutek software can download all of the stock maps through the Ecutek update (you might have already downloaded them all if you opted to in a previous run of the update module). You would just pick the stock file that matches your calibration ID and flash it like any other aftermarket tune.
Fred E is offline   Reply With Quote
Old 10-09-2018, 04:37 PM   #3
stlgrym3
So it’ll just be like ecu programming but with the stock file instead of custom tune? Which folder do those stock tune files reside in? Do I have to erase the Ecutek license in my cars ecu?
Old 10-10-2018, 03:23 AM   #4
steve99
You dont have to erase the licence to program to stock. Ecutek will flash the stock tune into car and licence will remain embedded in ecu, such that you could reflash the ecu to a tuned rom again with ecutek later if you wanted to.
Flashing to "stock" with ecutek also releases the ecu lock ie returns the access key sequences to normal so opensource or dealer flash tools can access and write to ecu.
However the ecutek licence is still embedded in stock rom so the CVN calibration verification number like a checksum is not stock and can be used to detect that ecu has been flashed evenp though its stock .
In addition if you or dealer writes to ecu while the ecutek stock rom is present in ecu the ecutek licience will be lost. You would then need to purchase a new licience or ask if ecutek would re creit the licience they usually want dealer paperwork showing dealer reflashed ecu
Old 10-10-2018, 05:59 AM   #5
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I think he's asking how to switch between the tunes:
[ame]https://www.youtube.com/watch?v=YBv_JQX3IfE[/ame]
NLSP is offline   Reply With Quote
Old 10-15-2018, 05:27 PM   #6
stlgrym3
I’m confused with the switching map thing. I simply want to reprogram ECU with stock tune so it won’t throw any CEL when I swap back the factory header.
Old 10-15-2018, 05:32 PM   #7
You have to flash the stock tune back onto the car, after you exchange the ethanol in your tank to gasoline, and after you take the header and flex fuel off of the car.
Old 10-15-2018, 05:35 PM   #8
stlgrym3
The actual process of flashing back stock tune will be same like flashing custom tune revision?
Old 10-15-2018, 05:55 PM   #9
Identical except picking a stock rom.
Old 10-16-2018, 09:37 PM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
There is a way to completely remove the Ecutek license and put the ECU back to stock, you need to add some letters to the stock rom file before flashing it if I'm not mistaken.
@steve99 will probably know more details?
Old 10-27-2018, 06:12 AM   #11
steve99
Correct you can completly erase licoence and bfe 100% stock , but your ecutek licience is lost and they will likely want money to renew it, so its not something you normally do.
Old 10-27-2018, 10:07 AM   #12
Sportsguy83
Drives: Limited BRZ
Sometimes to sell car back to dealer people want to take it 100% stock.
Do you know what is the letters that need to be added to the flash file? I’ve done it once and don’t remember.
Old 10-27-2018, 11:43 PM   #13
steve99
@Sportsguy83
Messaged you info
Reverting to stock, parts available FS septiq Miscellaneous 23 08-17-2016 12:07 AM
Help! Reverting TRD Quickshifter to stock daiheadjai Engine, Exhaust, Transmission 0 07-05-2016 08:38 PM
Tuner ecutek tune back to stock? Toyota John Software Tuning 16 04-27-2016 07:08 PM
Ecutek stage 2 tune on stock brz 01s0uljah Software Tuning 15 10-15-2013 02:52 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
