Old 09-17-2018, 11:55 AM   #1
Silver_Arrow
Drives: GT 86
Car VIBRATION
Hi Guys.
I need your expert advice. So, one month ago, after my mechanic changed my clutch kit, shortly after that change, my transmission started vibrating (like severe vibration). This happened after i drove the car for like 1-2 hours (with the engine being on idle for at least 45 mins during the 1-2 hrs). So, when it started vibrating, the CEL got on and even started blinking. What i did was I allowed the car to cool down and it was good to drive again except that the CEL continued to appear (but not blinking). I had it checked at a mechanic. The error read. Misfiring cylinder 3. So, what I did was i changed all 4 spark plugs and all 4 ignition coils. I was driving for 1 month and the car was fine except that today I drove for like 1-2 hrs and again my car was on idle for at least 30 mis during the stop for a break. So When i started driving again, the severe vibration got back on with the CEL blinking. I don't know what to do anymore. Anyone experienced this before? What can be the issue? Again, I allowed the car to cool down and it was good to go again after 30-45 mins.
Thanks for all your help
Silver_Arrow is offline   Reply With Quote
Old 09-17-2018, 11:56 AM   #2
Silver_Arrow
Drives: GT 86
Note that i never have this issue for short drives i.e. less than an hour
Old 09-17-2018, 12:18 PM   #3
humfrz
You might try disconnecting the negative battery terminal for a minute, step on the brake, reconnect the terminal. Re-setting the ECU may "fix" it.
Then again, maybe not -
humfrz
Old 09-17-2018, 01:40 PM   #4
Ultramaroon
not playing cards
Ultramaroon's Avatar
That #3 coil pack is prone to failure because the exhaust plumbing is so close to it. Are the heat shields all still in place?
Driveshaft vibration HELP ganz954 Engine, Exhaust, Transmission 24 11-26-2019 11:36 AM
Vibration when idle Mattstermh Issues | Warranty | Recalls / TSB 27 07-27-2016 12:12 AM
Vibration at 2000rpms Karl07 Issues | Warranty | Recalls / TSB 5 06-03-2016 04:47 AM
Weird vibration on my FRS Crb2126 Issues | Warranty | Recalls / TSB 4 04-23-2016 09:11 PM
