Old 09-13-2018, 10:06 AM   #1
Laz84
Drives: 2014 BRZ, 1991 Prelude Si 4WS
re-enable cold start on OTS stage 2 plus
Does someone know the values I need to change in rom raider in order to achieve normal cold start? I understand its not needed with catless header but I have a hi flow on the front pipe and would like a normal cold start.
the tune I have is the stage 2 plus v4.03
or, I see many prefer the V2 maps. Do they retain cold start?
Laz84 is offline   Reply With Quote
Old 09-13-2018, 01:10 PM   #2
tomm.brz
Drives: brz 2017 hksv2
v2 retain cold start, just a bit quieter maybe than stock because they lowered a bit the cold idle rpm
to re enable: copy all Idle speed target tables, under Idle control folder from a v2 tune or stock tune
copy the 2 Maf correction after start tables, under Mass airflow/engine load folder from a v2 or stock tune
change Ignition timing post start, under Ignition timing - advance folder from 0 to -15 or -17 (more negative is, louder is)
copy both Catalyst warm up tables, under Ignition Timing - compensation from v2 or stock tune
Old 09-13-2018, 03:38 PM   #3
tomm.brz
negative timings and maf compensation would do that job better than just idle rising, that would just increase engine wear with no purpouse
Old 12-23-2018, 02:40 PM   #4
scsftballnum45
Drives: BRZ 14'
Where can I find V2?
scsftballnum45 is offline   Reply With Quote
Old 12-23-2018, 11:38 PM   #5
steve99
Or copy them from a stock rom
Old 12-24-2018, 03:00 AM   #6
tomm.brz
Seems like Shiv removed v2 from his site
Old 04-30-2019, 10:32 PM   #7
MotoGrapher
Drives: 2014 White BRZ Limited
Came across this one. Does anyone know how to find and open a stock rom? Mine gave me all sorts of warning/errors...
MotoGrapher is offline   Reply With Quote
Old 05-01-2019, 09:44 PM   #8
MotoGrapher
Hi Steve, just wondering how to read stock ROM? I downloaded ZA1JB01C.ori file from OFT but could not open it correctly.
Thank you!
Old 05-01-2019, 09:49 PM   #9
steve99
Thank you!
See the Romraider Tips link below, you wilp need to downlad a stock b01C def file from github . Then you need to have corect def at top of lost in romraider as you open each tune type stock or oft
Old 05-03-2019, 05:18 PM   #10
elBarto
elBarto's Avatar
Drives: Toyota GT86
I still have the V2's on my Gdrive.
OTS V2.067
Carefull to not mix the def's. V2 B01C is totaly different from the V4 B01C.
If you are using the V4 B01C (with V4 definition), just open a V2 B00C (with V2 definition) and copy those values to your V4 B01C.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 08-11-2020, 11:10 AM   #11
D-VO
Drives: Whiteout FR-S, Evo 8 RS
Hey guys. I'm looking for the MAF Correction after start tables. They are not defined in the previously linked OTS files. I just finished setting up my A01C MAP to try on my 2013 since the B01C definitions were a little wonky. I've been searching for 2 hours, so any help would be appreciated. =)
D-VO is offline   Reply With Quote
Old 08-11-2020, 11:46 AM   #12
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
This is from a different ROM, ZA1JK00C, but it would apply if you're running OFT.
If you need data from ECUtek, I can get it but I'll need o go find my deskey
Old 08-11-2020, 11:55 PM   #13
D-VO
Thanks, but what I'm looking for is the definitions for the "MAF Correction after start" tables in the ROM's, not for the corrections for the tables. They'll look something like this:
<table name="MAF Correction After Start (Neutral)" address="11c868"/>
<table name="MAF Correction After Start (In Gear)" address="11c964"/>
So I'd need to know which ECT scalar is being used and I need a scaling for the "Idle mode" on the Y axis.
Old 08-12-2020, 06:45 PM   #14
D-VO
@steve99 Any ideas for me? I looked through some of the ROMRaider stuff but can't find then posted or in the 32bitbase.
need help to lower cold start w/OFT stage 1 vietspride70 Software Tuning 1 06-02-2021 03:17 AM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
