Old 09-11-2018, 11:28 AM   #1
Scala
Drives: 2018 BRZ tS
E85. Do you test it? Do you use a flex fuel kit?
Finally found a gas station near me, 12 miles away, that carries E85 but they can't tell how often it is tested.
In the US by law it can be as low as E51 and I'd like to know what I'm putting in the tank before I do. Testing it is not difficult but time consuming.
Do you use a flex fuel kit or do you just select the Stage 2+ on your OFT as long as you know that the fuel is E75+ ?
Thank you.
Scala is offline   Reply With Quote
Old 09-11-2018, 11:33 AM   #2
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
I don't test mine, but based off the readings I'm sure it's closer to E50 than E85
carsebuco is offline   Reply With Quote
Old 09-11-2018, 11:40 AM   #3
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Flex Fuel kit all the way. Take the guesswork out of it. My station usually is about 70-80%.
MCTeeJ is offline   Reply With Quote
Old 09-11-2018, 11:47 AM   #4
Code Monkey
Drives: Subaru BRZ
Just get a flex fuel kit.
Code Monkey is offline   Reply With Quote
Old 09-11-2018, 12:17 PM   #5
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I think in Cal the min is 70%. Mine is usually around 80%. To be safe, I would get the kit and tune. It is very cool being able just to fill up at either and the car figures it out for me.
Old 09-11-2018, 12:27 PM   #6
Scala
Drives: 2018 BRZ tS
Thanks for the replies. Do you guys run OFT or EcuTec?
Old 09-11-2018, 12:37 PM   #7
Code Monkey
Drives: Subaru BRZ
EcuTek.
Old 09-11-2018, 12:40 PM   #8
Scala
Drives: 2018 BRZ tS
Originally Posted by Code Monkey View Post
EcuTek.
Remote tune? How satisfied are you and why not OFT?
Old 09-11-2018, 12:47 PM   #9
I sure do. Flex fuel, and Ecutek.
PM me to order.
Old 09-11-2018, 12:53 PM   #10
Grady
Grady's Avatar
Flex fuel kit, ECUTEC, Remote tune (Very satisfied with Delicious). The station I get E85 from generally runs in the high 70’s, low 80’s at times.
I have tuned before but trying to learn tuning for E85 plus turbo, boost control I decided to go the easy route. With those combinations one mistake could cost a lot more than paying an experienced tuner to set up everything.
Old 09-11-2018, 12:55 PM   #11
Code Monkey
Drives: Subaru BRZ
Very satisfied with my remote Delicious tune. OFT is not as capable and I only want to buy once.
Old 09-11-2018, 02:43 PM   #12
bfrank1972
Drives: 2013 FR-S Argento
FYI ethanol grades vary from season to season (in areas with seasons), in winter fuel stations tend to have a lower ethanol to gas ratio, atomization is better in cold climates.
bfrank1972 is offline   Reply With Quote
Old 09-11-2018, 03:00 PM   #13
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I have the Delicious Flex Fuel kit. The nice thing about it, is that it comes with bluetooth that you can connect to your phone to check percentage. On average I get between 65% and 75% depending on the time of year.
AFAIK our cars only can take advantage of up to 60% so anything higher shouldn't make a huge difference. I could be wrong so if I am please correct me lol.
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 09-11-2018, 05:06 PM   #14
Scala
Drives: 2018 BRZ tS
Good news for me. GATE Petroleum is a Jacksonville FL headquartered company with ~ 100 gas stations throughout the SE all of which carry E85 that tests consistently at E80 or better.
As long as my BRZ is within range of a GATE station I won't be needing a flex fuel kit. One issue solved.
The decision between EcuTek and OFT is leaning toward the OFT for the time being and this is due to the ease of changing tune stages -E85 etc- and recovering the OE tune without third party assistance.
I must also confess that the not insignificant cost Δ Is an issue at this early stage when I'm not yet certain about this project's longevity.
Thanks to all for their input.
thinking of getting DT stage 2 flex fuel tune, do I need a flex fuel kit? stlgrym3 Engine, Exhaust, Transmission 4 03-23-2018 02:51 AM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
