Old 09-02-2018, 04:16 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Question for those have flex fuel kit installed
Are you switching fuels from tank to tank or stick with with either petro or E85 most of time? I was told it’s not good for our gas tank if we fill up with E85 all the time since it was not designed for it, any truth to this?
stlgrym3 is offline   Reply With Quote
Old 09-02-2018, 04:21 PM   #2
Lantanafrs2
Drives: 2013 frs red
I've never heard that. I've been using e85 only for a while now. It's all theory....til it isnt
Old 09-02-2018, 04:30 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Absolute bullshit. Any modern car (last 10 years especially so) has a fuel system to handle E15 fuel for the life of the car. That means it's fine with pretty much any concentration of ethanol.
Old 09-02-2018, 04:32 PM   #4
stlgrym3
So is it better for the car to stick with one fuel until you have the need for the other?
Old 09-02-2018, 04:37 PM   #5
Yoshoobaroo
TRACKBREAD
No, it really doesn't matter with a flexfuel sensor.
Old 09-02-2018, 05:19 PM   #6
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
yes stick with e85 because it smells better and you can sniff the nozel when done
Breadman is offline   Reply With Quote
Old 09-02-2018, 11:28 PM   #7
sid94
Drives: 2013 frs
I rode 4 years on straight e85 and now I’ve been on 93 for a year and now I’m switching back to e85 lmao it doesn’t mater like stated before now a days the cats can handle it not like back in the olden days
sid94 is offline   Reply With Quote
Old 09-03-2018, 05:24 AM   #8
The fuel switch is to help keep your valves clean. Ethanol does not have the detergents that pump gas has.
Old 09-03-2018, 05:41 AM   #9
tomm.brz
Drives: brz 2017 hksv2
? everybody always say that ethanol as a solvent cleans better the engine than petrol, you are now saying the opposite...
Old 09-03-2018, 08:16 AM   #10
Yoshoobaroo
TRACKBREAD
It depends where you get your gas. Ethanol itself works better as a solvent than gasoline, but top tier gasoline brands (Shell, Mobil, etc.) put extra detergents in the gasoline so it cleans better.
Old 09-03-2018, 08:18 AM   #11
stlgrym3
so you're suggesting use pump gas (such as daily driving) until i need the extra power?
Old 09-03-2018, 08:40 AM   #12
Breadman
Breadman's Avatar
citation needed, there is a federal requirement for what needs to go in
Old 09-03-2018, 11:58 AM   #13
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Top tier gas brands have been putting above the minimum needed since 1995, it's just a marketing tool now. The "extra" doesn't do anything except to convince you to get their brand.
Trueweltall is offline   Reply With Quote
Old 09-03-2018, 09:18 PM   #14
I recommend you just run a tank of 91 here and there. I run 91 through my brz every 3-5 tanks or so, typically on my way back from the track (because there is no ethanol by the tracks and I only take as much as I need to run the day).
Question for those who have flex fuel kit stlgrym3 Engine, Exhaust, Transmission 5 07-06-2018 11:47 AM
Noob Question...E85,UEL, Flex Fuel Kit? Swoldier86 Software Tuning 14 02-27-2018 08:51 AM
Flex fuel kit tuning question Captain Snooze Software Tuning 2 08-14-2015 10:57 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
