Old 01-25-2018, 11:41 AM   #1
Swoldier86
Swoldier86's Avatar
Drives: 2013 BRZ Limited
Noob Question...E85,UEL, Flex Fuel Kit?
I am wanting to make more power this year but not ready to go turbo yet still learning and deciding which route to build my car.
So I was thinking for now I could use e85, Flex Fuels kit, OFT, and UEL Headers.
I only have 1 gas station near me that just recently got flex fuel in it. So I would really want to run a flex fuel kit to be bale to change gases anytime if I need to.
I want UEL which I guess doesn't matter much in this scenario.
My main question is...can I run a flex fuel kit with the OFT and tune it to Stage 2 UEL e85? Or does the flex fuel kit interfere with the OFT?
Thanks for the help.
Swoldier86 is offline   Reply With Quote
Old 01-25-2018, 11:46 AM   #2
Somerandom18
Drives: 2017 manual BRZ
OFT sells a flex fuel kit that would be your best bet.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 01-25-2018, 11:46 AM   #3
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Open Flash is offering a flex fuel kit that is tuned with the OFT. Looks like you have to buy the kit from their website and then contact Shiv and he will send you the flex fuel tune that you are looking for.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
Old 01-25-2018, 11:56 AM   #4
Swoldier86
Swoldier86's Avatar
Awesome! Thanks for the reply. Do you know anyone who is running the OFT Flex Fuel with the OFT? Curious on how they like it.
Old 01-25-2018, 12:09 PM   #5
slowest86
Drives: slow frs
I have it, and I love it. You won't have launch control, or flat foot shift options tho.
slowest86 is offline   Reply With Quote
Old 02-16-2018, 09:53 AM   #6
89_Manny
89_Manny's Avatar
Drives: Firestorm FR-S '13
I’ve been debating on going with a flex fuel kit. Noooooob question! Does open flash tablet flex fuel kit also work like the delicious and moto-east flex fuel kits? Essentially I want fuel up on either 91 or e85 and just go with out reflashing my ecu....
Thank you ahead of time!!
89_Manny is offline   Reply With Quote
Old 02-16-2018, 11:10 AM   #7
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
You can use any flex fuel kit.
I'm using one I made based on Arduino. You'd just have to let Shiv know which one you're using, he'll want to know what the voltage is set for for which level of fuel.
Oh and it has to be going to the evap pin 20 on the ecu.
Total cost for my flex fuel kit was $150 with an edelbrock fuel filter and pnp harness.
Jaden
Jaden is offline   Reply With Quote
Old 02-16-2018, 11:44 AM   #8
pancake
Drives: 2015 BRZ Limited MT
Jaden
I am very curious about how you went about making one O.O
pancake is offline   Reply With Quote
Old 02-16-2018, 11:56 AM   #9
Jaden
Road-hole
There's threads here about making them.
Basically you use a GM flex fuel sensor that outputs 50-150hz based on the level of flex fuel detected and an arduino programmed to take that frequency signal and convert it to a voltage output that the ECU can use along with a FF tune to adjust the fueling and timing for FF.
In my case I also wanted a readout so I used an lcd readout for arduino and an arduino nano.
I was able to find both a FF sensor with fuel lines on ebay and then also a pnp harness so I didn't have to cut any wires for a very good price. Although it's perfectly possible to buy all of the stuff separately.
The pnp harness is like $90 new and the sensor is like $50. You can get the fuel lines and connectors as well. Not sure on the prices off the top of my head.
I bought the arduino nano for less than $10 and the lcd for $6.
I'm more than willing to share the code I have with anyone who wants it.
Also I'd be willing to put something together for you preprogrammed and ready to go for a little more as well. Or I can just prepare the arduino analyzer by itself.
There is some variation in the sensors and for mine I had to tune the calculations in the arduino code a bit to get it to read 100% accurate.
Jaden
I put mine in a location that is different than what most people do in the engine bay because I'm going for a total stealth approach.
When you look in my engine bay, you wouldn't know that it has flex fuel except for one blue and black fitting.
Old 02-16-2018, 12:05 PM   #10
89_Manny
89_Manny's Avatar
Jaden
I’m interested in the set up...
Old 02-16-2018, 12:52 PM   #11
Jaden
Road-hole
Here's a vlog break down of my setup for you.
[ame="https://www.youtube.com/watch?v=PEq5T-8rn3s"]Custom flex fuel for 86 - YouTube[/ame]
Feel free to pm me to let me know what you think.
Jaden
Old 02-16-2018, 10:27 PM   #12
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm not running flex fuel, but I am running e85 stage 2 uel tune. It's a noticeable difference over the 93 octane tune, really wakes the car up and makes it pull hard, you won't be disappointed.
Old 02-16-2018, 10:30 PM   #13
FRSBRZGT86FAN
Jaden
What's with the writing on your intake manifold?
Old 02-16-2018, 10:58 PM   #14
Jaden
Road-hole
It was a used engine out of a wrecked frs.
I spun a rod bearing on my first engine. This engine had been pulled out of a wrecked frs. I got a great deal though. This was two or three years ago and I got both the engine and trans for 3200 with 30K miles on it. So I'm going to build the other engine for mo' powr'....
They had marked on the intake manifold what it was out of to keep track I guess.
:shrug:
Jaden
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
Flex fuel kit tuning question Captain Snooze Software Tuning 2 08-14-2015 10:57 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
