Old 09-02-2018, 12:25 PM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
Thoughts after filled up with E85 for the first time
I finally passed the pumped gas portion of my tune revision. And now onto the ethanol. I filled up my tank yesterday with only 1/4 tank of 91 remained. I was told to take it easy first 10 miles or so, therefore, there aren’t any significant gain I’ve noticed, but the difference is definitely noticeable. I will get another data log tomorrow. I’m using delicious tuning’s ACE and Flex tune btw.
This morning when I turned on the car it vibrates a little more than before upon starting, and then back to normal. The same vibration is no longer there when I started the car up again after a 5 min drive to Starbucks. Was that the characteristic of ethanol?
stlgrym3 is offline   Reply With Quote
Old 09-02-2018, 12:29 PM   #2
Lantanafrs2
Drives: 2013 frs red
Give it time
Old 09-02-2018, 03:57 PM   #3
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
I just bought a used Delicious tuning Flex Fuel kit off the forums. I'll be switching to E85 on the stage 2 platform with JDL catless UEL headers, JDL ultra-quiet catted front/over pipe, MagnaFlow catback, and 3" Perrin intake.
Curious to see what your thoughts are!
majixmatrix is offline   Reply With Quote
Old 09-02-2018, 03:59 PM   #4
stlgrym3
I would get the Delicious Tuning custom tune for the JDL header and flex fuel kit.
Old 09-02-2018, 04:09 PM   #5
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
i have about 2k miles on the dt flex tune now and have ran anywere from a 50/50 93/flex to a tank reading 82% eth and never had that.
Breadman is offline   Reply With Quote
Old 09-02-2018, 08:27 PM   #6
bfrank1972
Drives: 2013 FR-S Argento
Normal. Probably some misfiring when the engine is cold - E85 doesn't atomize as well as gas when it's cool out. You can tweak your tune to enrich cold start fuel mixture to help with it (like an old school choke, runs richer, idles a bit higher until the engine warms). Some people have problems starting the car altogether on stock cold start values depending on the temperature.
bfrank1972 is offline   Reply With Quote
Old 09-02-2018, 09:26 PM   #7
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Also, if your tank was 1/4 full when you filled up and you've only driven a little over 10 miles since, there is a long way to go before the Saiyan power kicks in.
carsebuco is offline   Reply With Quote
Old 09-02-2018, 09:53 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yep totally normally, I've managed to assuage it a lot by messing with my tune, there are some tweaks present on this forum you can make to assists with cold starts under 50 degrees and it did make a legitimate difference. You can all have it use DI only on cold starts which seems to help. Ask for a tune edit if possible
Not sure if the dealer filled with 93. Spacemane969 Issues | Warranty | Recalls / TSB 23 06-17-2015 08:42 PM
Nitrogen Filled Tires SocalBurt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 12-02-2014 12:21 PM
Prescription Filled!!! SIC8D6 Scion FR-S / Toyota 86 GT86 General Forum 39 04-12-2014 01:47 AM
Dealer filled my new FRS with 87 octane; Should I flash ECU? Hakuzen Issues | Warranty | Recalls / TSB 37 01-09-2014 05:52 PM
FR-S TIME MACHINE - THOUGHTS? Davyator Scion FR-S / Toyota 86 GT86 General Forum 26 07-20-2012 12:32 PM
