Old 06-17-2015, 02:40 PM   #1
Spacemane969
Spacemane969's Avatar
Drives: 2013 ARGENTO A/T
Not sure if the dealer filled with 93.
I just purchased my 13' from the dealer and my salesman was completely surprised that it takes premium. I'm hoping that the maintenance guys filled the tank with premium. I didn't think to ask then, but guess I should give them a call, but in any case I'm already at a half tank (road trip)...
Just in case it wasn't, should I burn off whatever is left and then refill, or just refill with premium now at half full? Not sure if the mixture would matter.
Thanks, and what is the possible repercussion if they did fill it up with low grade?
Thanks
Spacemane969 is offline   Reply With Quote
Old 06-17-2015, 02:43 PM   #2
gramicci101
Off Topic
The ECU will pull timing if it senses knock and you'll be down on power until you can get decent gas in it. Just run it down and then refill as normal.
Old 06-17-2015, 02:45 PM   #3
STV3
Señor Member
STV3's Avatar
If they did, it's really not a big deal. Just drive the car easy until your next fill up.
Even if you push it, the ecu will detect any knock and compensate for it.
STV3 is offline   Reply With Quote
Old 06-17-2015, 02:46 PM   #4
STV3
Señor Member
STV3's Avatar
Yeah what he said... lol
Old 06-17-2015, 02:47 PM   #5
gramicci101
Off Topic
I win.
Old 06-17-2015, 02:50 PM   #6
STV3
Señor Member
STV3's Avatar
I win.
lol I had most of it typed, then a damn customer came in and I had to stop
Old 06-17-2015, 02:59 PM   #7
Abenaki
Curmudgeon@gezzer.com
Abenaki's Avatar
Wink
This would a great job if it weren't for the damned customers!
Abenaki is offline   Reply With Quote
Old 06-17-2015, 03:02 PM   #8
STV3
Señor Member
STV3's Avatar
Exactly!!!
Old 06-17-2015, 04:43 PM   #9
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Since it's a new car, you shouldn't be driving it too hard anyway. I wouldn't worry about it, you'll be fine.
Many dealerships have gas pumps in the lot that they use to fill up new car deliveries, rental cars, customer cars, etc. 99% it's 87 grade, unless they actually drove the car to a gas station and have a receipt for premium.
I used to work at a Nissan dealer back in 09' when the GTR first came out. We were the first dealer in New England to have one. Guess what we used to fill it up? 87, yup.
Jesse36m3 is offline   Reply With Quote
Old 06-17-2015, 04:56 PM   #10
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
It's Totalled....
ntron1 is offline   Reply With Quote
Old 06-17-2015, 05:14 PM   #11
Spacemane969
Thanks for the replies. Sorry I didn't specify that it's used not new. Haven't felt any knocks yet but i'll just wait until it empties out.
Old 06-17-2015, 05:21 PM   #12
Chanpion
Drives: 13 FRS Satin
It'll be fine, the ECU will adjust.
The car's supposed to take 94. If you're in the US, that's not premium, that's a step above it.
Chanpion is offline   Reply With Quote
Old 06-17-2015, 05:53 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Question: If you have only access to regular 87 octane and the next stop for premium gas is 300 miles away, will you freak out? Will you write off your engine?
Regular gas is only "bad" if you have an engine and ECU incapable of adjusting to the octane difference. Once in a while is okay.
-alex
Old 06-17-2015, 06:58 PM   #14
humfrz
YOU'RE FIRED ..... !!!!!!!!!!
YOU TOO ......Abenaki .....!!!!!!
Yo, we have two job openings ......
OP, your car will be just fine till you get some hi-test gas .....
humfrz
Nitrogen Filled Tires SocalBurt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 48 12-02-2014 12:21 PM
Is the front sway bar bushings liquid filled? Rayme Issues | Warranty | Recalls / TSB 13 10-02-2014 05:06 PM
filled up w e85 now car wont start..id1000s dw65s jdl kit kingkai23 Forced Induction 8 07-24-2014 10:56 AM
Prescription Filled!!! SIC8D6 Scion FR-S / Toyota 86 GT86 General Forum 39 04-12-2014 01:47 AM
Dealer filled my new FRS with 87 octane; Should I flash ECU? Hakuzen Issues | Warranty | Recalls / TSB 37 01-09-2014 05:52 PM
