Old 03-29-2014, 04:06 PM   #1
flashburn
Drives: 2014 Subaru BRZ Limited 6MT
Need help installing rear springs!
So I was following the guide here:
http://www.ft86club.com/forums/showthread.php?t=32414
I had no issues doing the front springs, but I'm about to lose it with the rear springs.
Someone mentioned that only three bolts needed to be removed to be able to pivot out the rear struts, "strut top nut, LCA to hub knuckle bolt, and stabilizer bar to endlink bolt.". However, I'm not sure which is the stabilizer bar to endlink bolt?
The other issue I'm having is I can't even remove the bolt to the LCA and hub knuckle. I got the nuts off, but as I was pushing through the bolt, it just got to the point where it wouldn't go any further. It seems like there is just too much pressure keeping it held against it.
I tried removing the bolt from the LCA and strut, just because I figured I'd remove the strut if there was no way around it, but the same exact problem there! I cannot remove the bolt completely. It seems like it's under too much load! I hope someone can help me, because I'm really at a loss at this point.
flashburn is offline   Reply With Quote
Old 03-29-2014, 04:14 PM   #2
getbent
Drives: 2013 FR-S Blue MT
Use a jack to take some pressure off the control arm, may make it easier to get the bolts out.
The stabilizer bar runs from one rear wheel to the other under the car. Where that bar connects to the endlink is what you want to disconnect. This will let the control arm drop down further to give you room to get the strut out.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 03-29-2014, 04:20 PM   #3
flashburn
That's the third bolt here (that I actually did remove thinking that was the one), right?
I did try using a jack to relieve some pressure, but it just seemed to raise the entire hub/stabilizer bar assembly, but maybe I raised it too much.
Old 03-29-2014, 04:30 PM   #4
flashburn
Argh, I've tried a bunch of times now with a jack, and maybe it relieves the pressure a little, the f'ing bolts still won't come out. Man, I can't seem to catch a break.
Stupid question, but what should I be jacking up? I thought it was the control arm, but if you look at the photo, it looks like it's the strut itself that is applying the pressure, so jacking up the control arm doesn't help with that.
Old 03-29-2014, 04:51 PM   #5
flashburn
Well, I got the bolt out from the strut to the LCA, I did it by carefully jacking up the strut to relieve the pressure off of the LCA. However I still cannot remove the bolt from the LCA and the Hub. It seems like the head of the bolt is hitting the back of the hub and doesn't have enough room to come out?
Replacing Struts and Installing Coil Springs DarrenDriven DIY (Do-It-Yourself) Guides 195 04-26-2017 04:15 PM
Clunking noise after installing springs JACK 8URT0N Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-28-2015 03:37 PM
What extra work is needed after installing springs? g0ast Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-04-2013 08:15 PM
How necessary is alignment after installing new springs? switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-22-2012 11:52 AM
Installing the AVO Rear Reinforcement Bracket AVOturboworld DIY (Do-It-Yourself) Guides 9 10-29-2012 11:44 AM
