| Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) Wash, Wax, Details, Repairs |
Anyone ever have this issue? (Turn Signals)
So the other day I noticed that my left turn signal was blinking really fast. Easy enough, I must have a burned out bulb.
Sure enough, my rear driver side bulb is out, so I buy a package of bulbs. I replaced the bulb, and tried the turn signal again, bulb is still out. I did some reading to see if there is possibly a fuse for only the rear driver side bulb, but no luck. Anyone know what this might be? I also tried multiple bulbs. Thanks! -Beau EDIT: My apologies Mods, I accidentally posted this in the wrong forum. I tried to delete it so I could repost, but couldn't find the option... Last edited by Jhangles; 08-22-2018 at 08:36 PM. Reason: Posted in wrong forum |
not playing cards
Are the terminals in the bulb socket possibly corroded? The circuit is pretty simple. If the front works, then the fault must lie somewhere between the junction box above your left foot and the ground junction. Can you read a wiring diagram?
#3 | |
Sent from my SM-G950U using Tapatalk |
#4 | |
not playing cards
https://demos.starbase7.net/t3Portal...bjType=ewdappu
#5 | |
not playing cards
Look again. I edited the link.
Turns out the connections in the socket were bent in too far at first, and then the other connection to the tail light came loose while I was messing with it.
| Turn signals issue, need help | pinetree | Issues | Warranty | Recalls / TSB | 18 | 07-09-2017 11:53 PM |
| Turn signals don't always automatically turn off | one2onejackpot | Issues | Warranty | Recalls / TSB | 6 | 04-18-2016 07:35 AM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 10:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
| OLM switchback turn signals issue | bakilman | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 01-20-2015 12:21 PM |
