Old 08-22-2018, 08:12 AM   #1
atomicalex
Drives: 2018 BRZ Limited Perf Pack
2018 USB port weirdness?
Has anyone else seen anything like this?
Periodically, my iPhone will do this charging on/off thing that results in really annoying dinging of the phone. I played with it a bit and discovered that my Android phone (plugged into the second of the two ports) is not charging at all.
It appears that the USB power controller is having issues.
Both phones are using good condition OEM cables, so that should not be an issue.
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon
atomicalex is offline   Reply With Quote
Old 09-03-2018, 12:42 AM   #2
Decep
Drives: 2013 FR-S Series 10
are you using the usb port for charging? i've always used 12v socket with a high quality name brand fast charger, as those USB ports generally suck and charge very slowly.
The Following User Says Thank You to Decep For This Useful Post:
atomicalex (09-03-2018)
Old 09-03-2018, 06:54 PM   #3
atomicalex
Yes, and that is good info. I will move my Android off that port.
www.atomicalex.com
Old 09-03-2018, 11:33 PM   #4
spike021
spike021's Avatar
Have you checked your iPhone's lightning port?
That thing is notorious for collecting lint and other junk. I recommend gently prying into it with a wooden toothpick and trying to remove as much clumps as you can.
Usually that crap prevents the charger from working all the time.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
2018, port, power, problem, usb
whole lot of weirdness/possible overheating shaynek Issues | Warranty | Recalls / TSB 7 08-01-2018 06:56 PM
CEL/Cruise Control weirdness MuseChaser Issues | Warranty | Recalls / TSB 10 09-01-2016 12:38 AM
USB port help _B_ Electronics | Audio | NAV | Infotainment 2 01-01-2014 09:36 PM
Heater control weirdness FRiSson Issues | Warranty | Recalls / TSB 0 03-29-2013 10:33 AM
Auto headlight weirdness Grimlock BRZ First-Gen (2012+) — General Topics 9 06-05-2012 02:40 PM
