Old 08-17-2018, 03:53 PM   #1
Rederick
Drives: 2017 BRZ PP, 88 Yota 4x4 SC'd
Dash rattle help
I have not been able to find another dash rattle like this when searching around. Was curious to see if anyone else has had this. It is really annoying, almost sounds like there is a wiring connector flopping around behind the head unit.
This rattle does not happen every day... I have tried putting pressure all over the center dash area pieces and nothing changes the noise as all that is why I think it is coming from behind some of the controls or head unit maybe.
https://photos.google.com/share/AF1Q...BxZ3hLYzk0ZlNn
This not my only rattle.. think I have something that sounds like a loose washer rattling around a screw head in my passenger door at certain RPMs. My head unit vibrates on the plastic trim, and occasionally my rear seat or center tail light rattles.
Thanks in advance!
Rederick is offline   Reply With Quote
Old 08-18-2018, 04:54 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Thanks in advance!
This car has a lot of rattles and such that are normal as you have probably found in research
For the door issue, you're going to need to take the door apart and add some kind of dynamat or felt to the mounts of the speaker and back of the bolts and such and make sure everything is torqued down and "tight" fitting
For the head unit rattle you can probably add felt or dynamat to the back of the trim where it seemingly rubs against the head unit or head unit mount brackets
You can use these techniques for the other rattles and try to narrow them down, but it's honestly going to be a loosing battle
Rattle from driver's side dash? Prog Issues | Warranty | Recalls / TSB 141 10-04-2019 12:01 AM
In Dash Rattle jezarus Issues | Warranty | Recalls / TSB 6 10-11-2015 09:35 PM
Rattle in the dash Capstan Scion FR-S / Toyota 86 GT86 General Forum 7 01-06-2015 07:41 PM
rattle behind the dash abutterman Issues | Warranty | Recalls / TSB 56 11-04-2014 11:31 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 11:09 AM
