Old 01-05-2015, 10:57 AM   #1
Capstan
Drives: 2013 Subaru BRZ
Rattle in the dash
I've got a 2013 BRZ and its been a great car, no problems whatsoever, but recently I am noticing a buzzy rattle coming from inside the dash somewhere when I drive on roads that are a little rough at some speeds (25-35 mph). I am suspecting a wiring harness or something that shook a little loose over time. The sound is really annoying.
I'm worried that this will be hard to find and fix. Is it covered under the warranty? Would they have to pull the dash off in order to get at the wiring in there and maybe ziptie it all up? Or can it mostly be reached from underneath?
Capstan is offline   Reply With Quote
Old 01-05-2015, 11:09 AM   #2
It should be covered under warranty but pretty tough to guess how far they will have to go to fix it.
I had a rattle in the dash and when I was in for oil change I mentioned it. The service guys seemed to know what it was right away and just reached up under and moved something and I never heard it again. The whole operation took about 5 seconds.
Old 01-05-2015, 11:56 AM   #3
8R6
8R6's Avatar
Drives: FRS
mine just started doing this too about 2 days ago!! i can usually deal with minor rattles and stuff, but this is more like somewhere between a buzz and a rattle and it's driving me nuts
8R6 is offline   Reply With Quote
Old 01-05-2015, 12:05 PM   #4
You want to hear the buzzes, rattles, pops, and other assorted noises you get when you drive these cars (or most others for that matter) once the temp hits -10 or so!
8R6 (01-05-2015)
Old 01-05-2015, 12:15 PM   #5
8R6
8R6's Avatar
Drives: FRS
good thing i live in socal where "freezing" to us means 40deg. LOL
Old 01-05-2015, 01:30 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
There are several relays and wires under the steering column that tend to get loose or rattle easily.
It will be covered under your basic 3 year/36K warranty, assuming you can replicate this issue at the dealer.
-alex
Old 01-05-2015, 01:37 PM   #7
Bergen23
Drives: '15 Halo FR-S
If they won't fix it, it isn't too hard to pull the lower dash out to check. But it may also be something in your HVAC system. When I had the lower dash off, it was super easy to locate everything and make sure it was all tight and secured.
Bergen23 is offline   Reply With Quote
Old 01-06-2015, 06:41 PM   #8
Capstan
That sounds a lot like what I am hearing. I go in for an oil change pretty soon, maybe they can solve it.
Rattle from driver's side dash? Prog Issues | Warranty | Recalls / TSB 141 10-03-2019 11:01 PM
rattle behind the dash abutterman Issues | Warranty | Recalls / TSB 56 11-04-2014 10:31 PM
FR-S dash rattle after Injen air intake install Tferritto Scion FR-S / Toyota 86 GT86 General Forum 2 06-29-2014 07:41 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 10:09 AM
Steering wheel/dash "rattle?" upon heavy acceleration? brett_g Issues | Warranty | Recalls / TSB 2 08-04-2012 04:52 AM
