Old 08-14-2018, 07:27 PM   #1
HachiRokuBoy
Drives: scion
Headlight wont turn on. Replaced bulb and fuses
Last night i tried to turn on my headlight but only one side was able to turn on.
today i went to go buy new fuses and bulbs but non of them worked. the car is completely stock.
I bought the 2015 fr-s used from a toyota dealer with extended 3 years/36k mile toyota extra care warranty. will toyota cover the expenses for the repair
HachiRokuBoy is offline   Reply With Quote
Old 08-14-2018, 09:06 PM   #2
BRZnut
Drives: BRZ DGM Limited
I would suspect that if it is not simply a burned out bulb then there is a more serious issue that a warrantee should cover, unless you have just a powertrain warrantee.
Old 08-14-2018, 09:11 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
First thing to inspect would be your warranty documentation, and to determine if you are under warranty.
If not, then do you own a multimeter?
Can you verify the HLP RH/LO 15a fuse is intact and didn't blow as soon as you tried to turn them on after replacing the fuse?
Which fuses did you replace in troubleshooting?
Did you try highbeams?
2013 FRS
Vortech V3 11psi
Old 08-19-2018, 06:14 PM   #4
dynomite619
dynomite619's Avatar
Drives: 2016 subaru brz insta@black.xira
mine did the same but i knew the problem because i bought used headlight and water got into it and burnt the module inside it. the module on ebay is $40 bucks if that is the issue .
dynomite619 is offline   Reply With Quote
URGENT!!! CAR WONT TURN OVER! Deagle50 Software Tuning 10 06-14-2016 02:12 AM
Auto Headlight Wont turn off with keyfob ru-x Cosmetic Modification (Interior/Exterior/Lighting) 26 12-24-2015 02:04 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 03:56 PM
Passenger Door Courtesy Light Wont Turn Off zex Issues | Warranty | Recalls / TSB 12 10-04-2013 01:31 PM
