Old 08-13-2018, 03:00 AM   #1
humfrz
Ambient temperature reading
Hi Folks,
This is the first thing on my 2013 FR-S, with 22,000 miles, that doesn't seem to be quite right.
I know, I should consider myself lucky -
The ambient air temperature reading seems to not want to go over 76 degrees F, regardless of the outside air temperature. Yes, it's been up to 95 degrees F in these parts here lately. Even after driving several miles (city driving) it seems to be stuck on 76 degrees.
I know, this is a first world problem -
My question is that how is your air temperature gauge read? Hi, low, right on?
If it's off, by about how much?
Thanks,
humfrz
Old 08-13-2018, 07:24 AM   #2
sly
sly's Avatar
Drives: 2016 Cosworth 2.2 BRZ
Mine did read about 3 degrees high until I relocated the sensor. It sits right next to the radiator and picks up heat. Bad design. I moved it forward from its current spot and now it's mostly accurate. You have to be moving though. When the car sits in traffic it reads high again.
sly is offline   Reply With Quote
The Following User Says Thank You to sly For This Useful Post:
humfrz (08-13-2018)
Old 08-13-2018, 07:58 AM   #3
BRZnut
Drives: BRZ DGM Limited
Mine is only accurate when the car is moving, otherwise it reads high.
The Following User Says Thank You to BRZnut For This Useful Post:
humfrz (08-13-2018)
Old 08-13-2018, 09:03 AM   #4
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
As long as the sensor is near the engine it'll read "hotter" because its next to a hot engine with no air flow. It's not that it's misreading, its just that its actually hotter air until you start moving again.
As for the OP, to me, I'd start troubleshooting with the sensor.
EDIT: Wait. for some reason I was thinking we were discussing the engine air intake temp sensor... not the reading on the gauge cluster... In that case, recently mine has read at most 110degF (90-95 actual) when I get out to my car after work.and start it up. It cools down after starting to drive.
BigTuna is offline   Reply With Quote
The Following 2 Users Say Thank You to BigTuna For This Useful Post:
humfrz (08-13-2018), jcw99 (08-13-2018)
Old 08-13-2018, 10:24 AM   #5
The highest mine has gone is 40. Has been as low as -25 though.
humfrz (08-13-2018), new2subaru (08-13-2018)
Old 08-13-2018, 03:28 PM   #6
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Hi Folks,
Thanks,
humfrz
It's pretty accurate on mine especially once moving and not standing still, I think it is able to be adjusted it in techstream however as I could've sworn there was a ambient air temp offset value in there somewhere
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
humfrz (08-13-2018)
Old 08-13-2018, 03:32 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Mine is always about 10 degrees F high.
humfrz (08-13-2018)
Old 08-13-2018, 03:39 PM   #8
sly
sly's Avatar
Yes. If you relocate the temp sensor forward and away from the radiator, put a piece of foil between it and the radiator to act as a heat shield, you can recalibrate it in techstream to make it 100% accurate. I haven't recalibrated mine yet.
humfrz (08-13-2018)
Old 08-13-2018, 03:40 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
Maybe you got the Bicentennial edition.
edj (08-13-2018), humfrz (08-13-2018), Tcoat (08-13-2018)
Where is the ambient temperature sensor located? solidONE Software Tuning 10 09-17-2023 03:21 PM
Ceramic Coated Ptuning Headers Ambient Temperature Testing s30series Engine, Exhaust, Transmission 32 03-17-2016 03:58 PM
Car/Ambient temperature to log data gdrider77 Software Tuning 6 01-19-2014 09:49 AM
Ambient temperature's influence on horsepower BuBlake Engine, Exhaust, Transmission 40 04-10-2013 01:17 AM
Temperature not reading below 0 BrewCity-FR-S Scion FR-S / Toyota 86 GT86 General Forum 6 01-22-2013 11:05 AM
