Old 08-08-2018, 11:02 PM   #1
mkodama
86 Challenge
Drives: 2017 BRZ
What do you think of this track alignment?
Thoughts?
mkodama is offline   Reply With Quote
Old 08-08-2018, 11:19 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
Not enough negative camber? It looks like they fiddled with toe, nothing else.
What do you have on the car for adjusting camber (assuming bolts up front, all stock in the rear)?
Old 08-08-2018, 11:22 PM   #3
mkodama
86 Challenge
Drives: 2017 BRZ
SPC Cam bolts in the front and SPC camber arms in the rear.
Old 08-08-2018, 11:53 PM   #4
FirstWinter
Drives: Car
I would advise more camber for tracking. You can get more camber from those parts. For the fronts use the bottom OEM bolt on the top slot of the knuckle and use the 14 mm SPC bolt for the bottom slot.
I noticed you were local as well. Not sure which shop you went to get your alignment but Elite Performance in Burlingame works on a bunch of our cars and they have never failed to get me excellent alignments.
If you plan on tracking you should come out to a 86 Drive Challenge event with us. See you at the track!
FirstWinter is offline   Reply With Quote
The Following 2 Users Say Thank You to FirstWinter For This Useful Post:
CSG Mike (08-09-2018), Tristor (09-01-2018)
Old 08-09-2018, 12:22 AM   #5
mkodama
86 Challenge
Drives: 2017 BRZ
After this alignment, I'm looking for a new place so I'll be checking Elite Performance out.
I was planning on 86 drive challenge, so just a matter of time before you'll see me out there.
Old 08-09-2018, 12:28 AM   #6
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
I got an alignment at Elite and was only able to get similar numbers in the front with camber bolts (-1.6). With lowering springs on my previous car I got -1.9 (also at Elite). Considering camber plates once I’m not worried about stock class in 86 Drive anymore.
TofuJoe is offline   Reply With Quote
Old 08-09-2018, 12:37 AM   #7
FirstWinter
Drives: Car
Did you try the trick by putting the OEM bolt on the top slot and the SPC bolt on the bottom for more camber? Should be able to get at least -2 degrees or more.
Old 08-09-2018, 01:10 AM   #8
tony_r
tony_r's Avatar
Drives: '15 STX
SPC + 14mm bolts can get up to -3.3 degrees with a 40mm offset wheel. Definitely can get a lot more if they know what they're doing.
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
FirstWinter (08-09-2018)
Old 08-09-2018, 08:06 AM   #9
Trust86
Drives: 2016 Halo FRS
Expect understeer
Trust86 is offline   Reply With Quote
Old 08-09-2018, 01:12 PM   #10
mkodama
86 Challenge
Drives: 2017 BRZ
I’m pretty annoyed at $280 for this “track alignment” where all they did was reduce rear left camber to factory specs and didn’t install the 14mm bolts like I asked.
Old 08-09-2018, 01:34 PM   #11
Icecreamtruk
Drives: Track preped NA FRS
Well go back and argue with them, because that is not a track alignement by a long shot. Not enough camber anywhere, toe-in in the rear but 0 toe on the front. If your objectif at the track is to destroy the shoulders of your tires while enjoying massive amounts of understeer, then this is really good...
Old 08-09-2018, 01:39 PM   #12
tony_r
tony_r's Avatar
Drives: '15 STX
It's further for you, but Auto Innovations in Milpitas can put in custom settings for ~$120 (typically $80 but more for strut cars).
$280 is a ripoff, even for "knowledge" etc from a race shop. I would never return.
The Following 2 Users Say Thank You to tony_r For This Useful Post:
FirstWinter (08-09-2018), Racecomp Engineering (08-31-2018)
Old 08-09-2018, 03:38 PM   #13
FirstWinter
Drives: Car
Holy shit man. Yeah, I wouldn't return to that shop. Usual rate in the Bay for custom alignments for track cars run $120 from what I've seen.
The Following User Says Thank You to FirstWinter For This Useful Post:
Old 08-09-2018, 04:16 PM   #14
Code Monkey
Drives: Subaru BRZ
$75 here for any specs I want, at $280 I would say fuck it and buy my own equipment, at those rates it would pay for itself in a year or two.
Code Monkey is offline   Reply With Quote
The Following User Says Thank You to Code Monkey For This Useful Post:
Alignment Changed at Track Event? Jamestl Tracking / Autocross / HPDE / Drifting 13 08-02-2017 12:07 AM
Post your track alignment ayau Tracking / Autocross / HPDE / Drifting 60 07-01-2016 10:27 PM
Looking for DD/track/autocross alignment suggestions. Lynxis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-12-2016 01:30 PM
dream track alignment? puma Tracking / Autocross / HPDE / Drifting 25 06-15-2014 08:32 PM
Alignment help, track day comin up boonFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-27-2012 05:39 AM
