Drives: brz
frs feed line size
hi
i wanted to know what size is the fuel feed line is it 5/16 or 3/8 im trying to install digital fuel gauge to check if my fuel pressure drops at wot thanks |
#2 | |
Drives: 2015 Subaru BRZ Series.blue
I would recommend the below option. I had a gauge pod and 3 gauges. It cost me like $800. I gave up once I bought the fuel pressure gauge. Too much work. I scrapped it and went with this instead and so glad I did. For $<400 I have almost any gauge you can think of at my fingertips when I want. It also has 1/4 mile timer and many others including 0-60. I know it's not the answer you requested but wanted to share how cool these Android decks are with ob2 XTRONS 7 Inch Android 8.0 Octa Core 4G RAM 32G ROM HD Digital Multi-touch Screen Car Stereo GPS Radio OBD2 TPMS Double 2 Din https://www.amazon.com/dp/B0792X89SH..._2ZqABb55937C4 BAFX Products Bluetooth Diagnostic OBDII Reader/Scanner for Android Devices https://www.amazon.com/dp/B005NLQAHS..._Z0qABb9D9E964 https://play.google.com/store/apps/d...ions.TouchScan Sent from my HTC U11 life using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. Last edited by Strife26; 08-06-2018 at 11:14 PM. Reason: Adding more info |
Drives: 2013 frs
5/16. The car doesn’t have a low pressure sensor so you’ll only be able to monitor the high side fuel pressure sensor with the app on the radio. Low side you’re better off just T ing into the fuel line/rail and put a mechanical one there for fault tracing use
#4 | |
Drives: brz
#5 | |
Drives: brz
if after the regulator what is the best method to hook up a guage? https://www.amazon.com/Nitrous-Expre.../dp/B003BBFOZQ this is what i was thinking of using to check the pressure with before the regulator |
#6 | |
Drives: 2013 frs
We have no regulator. Our fuel pump has a duty cycle and it goes up and down depending on load iirc. If you have a mechanical gauge like the auto meter ones that run into the cabin then it should work. But if you’re just planning on putting a gauge up to it right there I don’t see what the advantage would be as you can’t see it when you’re driving. Sent from my iPhone using Tapatalk |
| Help! Brake line leakage after steel braided line install. | ysu | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 26 | 02-09-2020 10:38 PM |
| Clutch Master Cylinder hard line Fiting size? | celek | Engine, Exhaust, Transmission | 7 | 03-12-2018 08:30 AM |
| Greddy Oil Feed Line | tubsaub | Forced Induction | 3 | 04-07-2015 04:02 AM |
| Turbo oil feed | mhiscott | Forced Induction | 13 | 10-28-2014 05:51 PM |
| Tapping my oil feed | Silverdub | Forced Induction | 9 | 10-17-2012 04:22 PM |
