Old 08-06-2018, 11:43 PM   #1
QTR FMS
Drives: brz
frs feed line size
hi
i wanted to know what size is the fuel feed line is it 5/16 or 3/8 im trying to install digital fuel gauge to check if my fuel pressure drops at wot
thanks
QTR FMS is offline   Reply With Quote
Old 08-07-2018, 12:11 AM   #2
Strife26
Strife26's Avatar
Drives: 2015 Subaru BRZ Series.blue
Originally Posted by QTR FMS View Post
hi
thanks
I would recommend the below option. I had a gauge pod and 3 gauges. It cost me like $800. I gave up once I bought the fuel pressure gauge. Too much work.
I scrapped it and went with this instead and so glad I did. For $<400 I have almost any gauge you can think of at my fingertips when I want. It also has 1/4 mile timer and many others including 0-60.
I know it's not the answer you requested but wanted to share how cool these Android decks are with ob2
XTRONS 7 Inch Android 8.0 Octa Core 4G RAM 32G ROM HD Digital Multi-touch Screen Car Stereo GPS Radio OBD2 TPMS Double 2 Din https://www.amazon.com/dp/B0792X89SH..._2ZqABb55937C4
BAFX Products Bluetooth Diagnostic OBDII Reader/Scanner for Android Devices https://www.amazon.com/dp/B005NLQAHS..._Z0qABb9D9E964
https://play.google.com/store/apps/d...ions.TouchScan
Sent from my HTC U11 life using Tapatalk
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks.
Strife26 is offline   Reply With Quote
The Following User Says Thank You to Strife26 For This Useful Post:
QTR FMS (08-07-2018)
Old 08-07-2018, 01:20 AM   #3
sid94
Drives: 2013 frs
5/16. The car doesn’t have a low pressure sensor so you’ll only be able to monitor the high side fuel pressure sensor with the app on the radio. Low side you’re better off just T ing into the fuel line/rail and put a mechanical one there for fault tracing use
sid94 is offline   Reply With Quote
The Following User Says Thank You to sid94 For This Useful Post:
Old 08-07-2018, 02:45 AM   #4
QTR FMS
Drives: brz
thanks the android screen looks awesome for data logging when tuning i might consider it for another car
The Following User Says Thank You to QTR FMS For This Useful Post:
Strife26 (08-07-2018)
Old 08-07-2018, 02:50 AM   #5
QTR FMS
Drives: brz
oh wait would i be able to check fuel pressure before the regulator? or does it have to be after the regulator?
if after the regulator what is the best method to hook up a guage?
https://www.amazon.com/Nitrous-Expre.../dp/B003BBFOZQ
this is what i was thinking of using to check the pressure with before the regulator
Old 08-07-2018, 09:37 AM   #6
sid94
Drives: 2013 frs
We have no regulator. Our fuel pump has a duty cycle and it goes up and down depending on load iirc. If you have a mechanical gauge like the auto meter ones that run into the cabin then it should work. But if you’re just planning on putting a gauge up to it right there I don’t see what the advantage would be as you can’t see it when you’re driving.
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 11:38 PM
Clutch Master Cylinder hard line Fiting size? celek Engine, Exhaust, Transmission 7 03-12-2018 09:30 AM
Greddy Oil Feed Line tubsaub Forced Induction 3 04-07-2015 05:02 AM
Turbo oil feed mhiscott Forced Induction 13 10-28-2014 06:51 PM
Tapping my oil feed Silverdub Forced Induction 9 10-17-2012 05:22 PM
