Old 05-28-2014, 07:00 PM   #1
Victor Draken
Drives: Toyota Gt86
DRONE!!! full exhaust
Hey guys!
I just installed: EL nameless header - DP/OP 2.5 Nameless catted and resonated - Perrin 3" catback resonated
Sound is fantastic... BUT it start droning from 3,5k rpm as soon as I go WOT and it never ends till the redline : /
Any idea? Is it normal? I believed that the Perrin resonated even if 3" was kinda tamed and almost drone free.
Right now I'm seriously considering having the stock catback put on again because the drone is too annoying.
Could it takes a bit of time to settle down maybe?
Is it possivle that the exhaust touch somewhere and produce the drone?
Victor Draken is offline   Reply With Quote
Old 05-28-2014, 07:03 PM   #2
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
is your header cat or catless?
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 05-28-2014, 07:06 PM   #3
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
The nameless header is catless.
OP what type of resonator on you DP/OP combo?
Freeman is offline   Reply With Quote
Old 05-28-2014, 07:22 PM   #4
Victor Draken
Drives: Toyota Gt86
Helmothz I need to double check under the car, but that's what I ordered.
Old 05-28-2014, 08:57 PM   #5
twag4
Drives: frs
I thought drone was at a stabilized RPM. Such as driving down the freeway at 70mph (112km/hour) and the exhaust note gets loud, or loud and hollow sounding. Engines get loud at wide open throttle at high RPMs. I don't believe that is drone, that is noise. What you're describing sounds like loud exhaust. Fix: don't drive at wide open throttle.
twag4 is offline   Reply With Quote
Old 05-28-2014, 09:04 PM   #6
Freeman
Freeman's Avatar
Originally Posted by twag4 View Post
I thought drone was at a stabilized RPM. Such as driving down the freeway at 70mph and the exhaust note gets loud, or loud and hollow sounding. Engines get loud at wide open throttle at high RPMs. I don't believe that is drone, that is noise.
I didn't even catch that. Now that I reread it, I completely agree.
I have the Nameless 3 inch OP/DP combo with straight through resonator and helmholtz resonator and Perrin resonated 3 inch cat back. I ran it with a Borla UEL header for a while. It was great. Loud and rumbly past about 3k rpms.
OP if you want to make it quieter, go with the Perrin 2.5 inch resonated cat back
Old 05-28-2014, 09:11 PM   #7
mike the snake
Also, after a while all exhaust systems will quiet up a bit, drone will be less.
Once the inside of the exhaust system gets coated with carbon and soot, the sound gets softer and drone became less on my last car.
Drone is weird sometimes. I've seen two identical exhausts on the same type of cars that were very different.
I have FB Premium stage 1 (header pipes are of thicker, different stainless) turbo kit, Nameless 3'' catless front/overpipe, Tomei 80r titanium exhaust, and while it is loud, there is zero drone at any rpm.
I also think on our cars that cam timing/tune can affect the drone a LOT. A different tune might be all that's needed to eliminate, or alter the drone.
Old 05-28-2014, 10:27 PM   #8
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
For a turbo car the Perrin 3 inch seems to be a good set up. For a regular 86, the Corsa catback is the best setup.
Disclaimer: I don't own either; just from sound clips I have heard of all of them neither the Perrin nor the Corsa have drone.
Old 05-28-2014, 10:47 PM   #9
steve99
What people refer to as drone is gnerally resonence, this is where one or more components of the exhaust are excited into occilations at the resonent frequency. This generally happns in an rpm band where the vibrations producd by engine or exhaust pulses are around the resonant frequency of one or more of the components.
If your unlucky or exhaust is porly designed it may happn in one or two rpm ranges, resonators are desigend to absorb or dampen these osilations.
Unfortunatly when you use components from several manufacturers its possible you have been very unlucky and although th individual components are fine the combination is the problem and may have changed the resonant frequencys away from the frequencys the resonator were originally designed to counteract.
You could try different resonators, it seems unusual the resonance is over such a large rpm range might also be worth checking thee mountings and clearances to ensure no part of the exhaust is not rubbibg or vibrating on the chassis or suspension components.
Old 05-29-2014, 03:42 AM   #10
Victor Draken
Drives: Toyota Gt86
I believe is rubbing or vibrating somewhere... It must be... because it's like a metallic vibration that start when the rpm increase and it keeps doing it. Like when you place a super small bolt in a metallic box and you make it vibrate inside of it.
I'm freaking out now, because the mechanic that did the work is out for 2 weeks and I'm worried it could create some problem if it's hitting or rubbing somewhere, hope not.
Old 05-29-2014, 03:47 AM   #11
Sphirit
Drives: GT86
Try the stock front pipe, it has a hemolz resonator.
Sphirit is offline   Reply With Quote
Old 05-29-2014, 05:20 AM   #12
steve99
yes definitly sounds like it a mechanical problem , its likely an easy fix .If your going to do a lot of driving its probably worth getting someone (or you) to look at it sooner.
Old 05-29-2014, 05:25 AM   #13
Victor Draken
Drives: Toyota Gt86
will go on the lift for an alignment today, I'll have a look and make some pics.
Yes I'll use it to commute from home to work, everyday. Damn it
Old 05-29-2014, 05:28 AM   #14
BrandonB
Drives: 2014 Whiteout Monogram Frs
I remember when I first installed my catted front pipe and 3" Perrin it was really loud for the first two days but after that it got a lot quieter
BrandonB is offline   Reply With Quote
UR Full Exhaust $1000!!!!! GT86_KiD NY / NJ / CT / PA 1 04-20-2014 07:06 PM
Full borla Exhaust soon Flashgodspeed Engine, Exhaust, Transmission 6 04-14-2014 03:41 PM
My FR-S full exhaust[video] MountainManFR-S FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 03-03-2014 02:47 PM
Full Stock Exhaust - Anyone content with full stock & NEVER planning for aftermarket? fooddude Engine, Exhaust, Transmission 39 12-15-2013 02:05 PM
US spy drone tranzformer Off-Topic Lounge [WARNING: NO POLITICS] 44 12-16-2011 05:51 PM
