Old 08-03-2018, 09:43 PM   #1
sid94
Drives: 2013 frs
Wastegate flutter!!
What’s up guys
Since I switched to 15psi my car now has the typical wastegate flutter and it’s annoying! I’ve heard other boosted twins and they don’t flutter like this
Insight on my engine I have a built bottom end 10.5:1 ratio Manley turbo tuff rods. Full blown turbo kit with GTX28 1000cc injectors AEM fuel pump. I’m using a Mac 3port solenoid for boost control and a 10psi spring in my wastegate. Tuned by James Martin on 93 for now
When I’m on my 15psi map it flutters but when I’m on 10psi it does not. I saw the company 23 boost controller doesn’t do this but what other boost controllers do you guys have that don’t make this flutter or what have you done to correct it?
sid94 is offline   Reply With Quote
Old 08-03-2018, 10:09 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
I will assume you mean turbo flutter.
As the wastegate has nothing to do with that sound.
I'm also going to assume it's not full on compressor surge that occurs while at WOT.
Figure out what your BOV needs to be set to.
Old 08-03-2018, 10:14 PM   #3
Fred E
Drives: WRB BRZ
If you mean the wastegate operation sound, that has to do with the wastegate duty cycle set within the Ecutek tune. Since James doesn't lock his tunes, you can edit this value yourself. He typically has his tunes set to 10, but you could experiment with higher numbers so the wastegate operates "faster" in that it opens and closes faster producing different sounds. I believe the map is called the "CPC Duty Multiplier" map, and Ecutek's tuning PDF has a section on this and they recommend 20-30.
Fred E is offline   Reply With Quote
Old 08-03-2018, 10:15 PM   #4
sid94
Drives: 2013 frs
It’s the typical subie flutter when you have an external wastegate. Not compressor surge and I have the proper spring in my BOV I’ve double checked with tial already
Old 08-03-2018, 10:29 PM   #5
sid94
Drives: 2013 frs
I’ll have to ask him I’d rather let him do it Incase I mess something up but yea the wastegate sound is what’s driving me up the wall. However I’m supposed to be at 15 but it starts at around 12 but the wastegate doesn’t actually open till 15
Old 08-03-2018, 10:45 PM   #6
x808drifter
LMGTFY
The "typical subie flutter" I see 9/10 is mistaken turbo flutter.
That's why I assume that first.
If this is what you are talking about, this is turbo flutter.
And is usually caused by the BOV not opening, or closing too soon.
[ame]https://www.youtube.com/watch?v=z2SIkhr2rcs[/ame]
If your wastegate is fluttering you would have sporadic boost.
This is wastegate flutter should sound like.
[ame]https://www.youtube.com/watch?v=G_MC8F1ANeo[/ame]
And even then isn't actual "flutter". His sounds like that because of the UEL exhaust leading to his wastegate.
This is actual wastegate flutter.
[ame]https://www.youtube.com/watch?v=_K0LFadOKBc[/ame]
If number one.
BOV
If number 2/3.
Then yes since you have a kit with an EL header thats just your EBC doing that. I'd say that what Fred said would work.
Old 08-03-2018, 10:57 PM   #7
sid94
Drives: 2013 frs
If number one.
BOV
If number 2/3.
Mine is more like video 3 so I guess I’ll talk with James and see if he can get that fixed for me
Old 08-06-2018, 09:39 AM   #8
Fred E
Drives: WRB BRZ
Yup, just ask him to increase the wastegate duty cycle/frequency. That will makes the wastegate operate with a higher frequency and should even out the sound.
Old 08-06-2018, 10:06 AM   #9
sid94
Drives: 2013 frs
I emailed him on Friday, still waiting on a response
Old 08-08-2018, 03:21 PM   #10
Kris86
Kris86's Avatar
Drives: RHD Gt86
Mine does it too
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 08-08-2018, 06:58 PM   #11
sid94
Drives: 2013 frs
Originally Posted by Kris86 View Post
Mine does it too
I heard it was a built Subaru engine thing lol, James sent me a updated tune last night with a higher cpc frequency said it should fix my issue but I haven’t gone for a test hit yet. And I’ve been debating on switching to a gt30 how does it feel? Sounds awesome
The Following User Says Thank You to sid94 For This Useful Post:
Kris86 (08-08-2018)
Old 08-08-2018, 07:18 PM   #12
Kris86
Kris86's Avatar
Drives: RHD Gt86
I went back and forth with my tuner and he basically said it’s the boost solenoid rapidly opening and closing to help build the boost pressure quicker to spool the turbo faster. Gonna be updating my software with him shortly and try dial in the tune some more, when I get time from work.
Tbh, I hate to hear it too n hope that he can eventually find a way to get ride of it lol
The gtx3076 gen 2 turbo is a beast, pulls like a freight train to redline. 8k
N the gen2 gtx series turbo spool sound amazing
Made 461hp on 91 octane 27psi ( running very low compression because I have shit pump fuel where I live, CP 9.0:1)
Waiting until I upgrade my drivetrain to do E85
Old 08-08-2018, 07:29 PM   #13
sid94
Drives: 2013 frs
I have the gen 1 GTx28 on 93 so far only 15psi but I’m 10:5:1 haven’t dyno’d but I’m soon switching to 18psi on e85 maybe 20
Old 08-08-2018, 08:01 PM   #14
Turbo
Drives: FR-S Turbo
wow - ok. SO my car sounds like example video #1. I just thought it was just the Tial blow off valve on my car sounding different than blow off valves I've had on other cars. Looks like I have some work to do.
Looked online and haven't found a video on how to adjust the Tial Q valve yet. From Tial's 'exploded view' diagram, it appears all I can do is change the spring?
Turbo is offline   Reply With Quote
Benefits of Recirculating Wastegate Strife26 Forced Induction 5 12-03-2017 09:27 PM
External Wastegate Question TurboBRZ Forced Induction 23 07-22-2015 12:38 PM
How to size wastegate crazyfrenchbiker Forced Induction 8 04-17-2015 05:06 PM
Fs:SoCal tial f41 wastegate enjetek Engine, Exhaust, Bolt-Ons 2 11-20-2014 11:30 AM
Hood flutter at high speed TheseColorsDontRun Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 09-10-2013 10:39 AM
