Drives: 2015 Subaru BRZ Series.blue
Benefits of Recirculating Wastegate
Does having an electronic boost controller with an external wastegate recirculation tube have any benefit? Or is it the same whether you have a boost controller or not?
Please only adult answers.
I'm stupid, retarded, a fkn idiot, and I will kill myself after a couple answers, I already know this (thanks to the interwebs and its logic) so feel free to leave those responses out, thanks. |
Drives: 2014 BRZ
What type of BC are you talking about? Standalone electronic, or a boost control solenoid? There are benefits to using them yes, and whether you recirc your wastegate or not has nothing to do with one another.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
| The Following User Says Thank You to Amputechture For This Useful Post: | ATL BRZ (12-01-2017) |
#3 | |
I wasn't sure if there was a way to use what would be recirculated to help boost stay constant or something, then recirc what's unneeded. Not gonna lie, I am crash coursing turbo info beyond the basics I understood. I know how it works, etc, but I am trying to learn the finer details to understand limits and well, anything there is that I can learn. So far it doesn't seem too complex, but I can't find specific details like my question here. Sorry if it's a newb question.
#4 | |
Drives: 2014 Scion FR-S Monogram
But as for the boost controller it will function the same way whether the wastegate is dumping or recirculating. The only difference between those two are dumping goes straight to atmosphere with no muffling, whereas recirculating diverts it into the exhaust system just like a car that comes stock with a turbo and internal wastegate. The way the wastegate controls boost levels is it has a spring inside that holds a certain amount of boost before opening and diverting the exhaust gases away from the turbine wheel in the turbo. A boost controller is attached to a vacuum line that normally feeds straight from a boost source to the wastegate and it bleeds off some of the boost pressure to allow the wastegate to stay closed at higher pressure levels.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
| The Following User Says Thank You to Detroiter For This Useful Post: | Strife26 (12-02-2017) |
#5 | |
I have been hunting down useful youtube videos. Mega Mechatronics had some informational videos that helped a lot. It's all very interesting so far. I'd love to tune my own car eventually.
Drives: 2014 BRZ
I share Detroit's sentiments, nothing wrong with an inquiring mind! Your solenoid is going to be hooked up to a vacuum source, so that it can tell what your manifold pressure is. In other words if a 'metaphor' helps at all, it's tapped into the intake side rather than exhaust.
| The Following User Says Thank You to Amputechture For This Useful Post: | Strife26 (12-04-2017) |
| VTA or Recirculating Catch Cans | VABeachBRZ | Engine, Exhaust, Transmission | 25 | 11-04-2016 07:25 AM |
| Brz/Frs Maperformance recirculating downpipe | Bens14Brz | Want-To-Buy Requests | 0 | 05-23-2016 11:58 AM |
| Silly question about a wastegate. | els7x5 | Forced Induction | 5 | 12-21-2015 10:01 AM |
| External Wastegate Question | TurboBRZ | Forced Induction | 23 | 07-22-2015 12:38 PM |
| How to size wastegate | crazyfrenchbiker | Forced Induction | 8 | 04-17-2015 05:06 PM |
