Old 08-03-2018, 08:10 PM   #1
Zer0
Drives: 2015 frs
Oil pan to crossmember clearance on Vorshlag mounts.
Looking for info on clearance between the oil pan, and crossmember. I have a set of Vorshlag mounts but may sell them due to changing the engine choice. I would like to build a new set of mounts built in the same style. So I was just inquiring about the clearance people had below the pan when using the Vorshlag kit as I would be building something similar. Or chopping them up to get them to work.
Zer0 is offline   Reply With Quote
Old 08-04-2018, 04:44 PM   #2
wooly35
Drives: 2014 Scion FR-S LS3
there is zero clearance between the oil pan and crossmember... even notching out the wings will give minimal clearance
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
Old 08-04-2018, 05:25 PM   #3
Zer0
Drives: 2015 frs
The pan bottom sits on the crossmember? How deep is the pan where it contact s crossmember. I'm going dry sump my pan is
1 3/4" deep. Thanks for this info.
Old 08-04-2018, 08:53 PM   #4
wooly35
I measured and it looks like mine is 2 inches deep where its sits over the crossmember. so if yours is 1 3/4 deep, you should be fine. although you still may have to notch out the wings to clear the steering crossmember.
Old 08-04-2018, 09:03 PM   #5
Zer0
Drives: 2015 frs
No wings
Old 08-04-2018, 09:36 PM   #6
wooly35
nice. mine is a wet sump, so I have no idea what the dry sump set up looked like. lol
Old 08-04-2018, 10:18 PM   #7
Zer0
Drives: 2015 frs
It's a aftermarket unit. I'm going to try to push it back to the firewall or through it a little a flat pan will help in that regard. Do you think your pan is going to last long term, and or are you going to fine tune the fitment?
Old 08-05-2018, 06:03 PM   #8
wooly35
I do believe it will last with where it sits now. I just did a 200 mile cruise through some fun back roads with my kc group today. Lots of high revs and curves. I came back home and everything looks great. Nothing went wrong. Oil pan still has the same clearance as before. I do plan on FI sometime in the near future with no plans of changing the oil pan.
Im a little over 5k miles on the swap.
Old 08-05-2018, 07:13 PM   #9
Zer0
Drives: 2015 frs
Nice. Glad to see people out there enjoying swapped builds.
Can I replace the front crossmember Dr.Spocktagon Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 03-08-2018 03:57 PM
Whiteline crossmember bushing insert review Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 11-09-2016 03:30 PM
AVO Transmission Crossmember Bushing Install Pix Infamous Performance DIY (Do-It-Yourself) Guides 0 09-29-2014 03:48 PM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
