Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > NY / NJ / CT / PA
NY / NJ / CT / PA NY, NJ, CT, PA
Old 08-02-2018, 12:10 PM   #1
02.ACCORD.DUDE
Car N00B
Drives: Honda Accord (2002)
Exhaust Alignment NJ?
Any recommendations for an exhaust shop that can help me get the alignment right on my ARK exhaust?
It's wayyy too far to the right. When my car was in for repairs I asked the body shop and they mostly fixed the alignment, but it turned out to only be temporary as the exhaust is again sitting too far to the right in the cutouts.
02.ACCORD.DUDE is offline   Reply With Quote
Old 09-14-2018, 09:30 AM   #2
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
My buddy club exhaust did the same thing. Check to make sure you didn't tighten one of the bolts (that connects it to the front pipe) too tight on one side. If they're both even the only way to fix it would be to cut a hanger off, put the exhaust where you want it to sit and weld in another hanger (and make sure there's a bit of pressure on it).
Edit: any exhaust shop will be able to do this for you for relatively cheap (don't pay more than like $40 for it MAX)
Instagram - @David_bobb
Build Thread - http://www.ft86club.com/forums/showthread.php?t=124218
DavidBob is offline   Reply With Quote
Alignment settings/Alignment Shop v1beeee CANADA 27 04-24-2017 04:54 PM
Camber/alignment for Eibach Prokit and when should I get alignment? Meanderchap Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 02-01-2016 03:44 AM
Exhaust Alignment bozack Engine, Exhaust, Transmission 13 06-05-2015 04:42 PM
DIY alignment - quick way to set alignment while new suspension settles? 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-11-2014 09:53 PM
Exhaust Alignment? bottle CANADA 5 11-13-2014 07:31 PM
