| DIY (Do-It-Yourself) Guides For all DIYs. |
520
Drives: Series 10 Fr-s #520
Maintenance to driveline components?
Without crawling under my 2013 FR-S.....are there any items in the driveline that need regular greasing or other maintenance? Like a U-joint or slip yoke on the driveshaft?
I don't drive hard, or track my MT model, but there seems to be some slack in the driveline - with 27K miles. looking for easy answers. Thanks. |
[insert cool phrase here]
Drives: BRZ Premium
No where in the service manual does it say to service the drive shaft under 100k....but shit happens you never know.
What I think you are experiencing is loose axle nuts. Either get them re torque or get new axle nuts.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#3 | |
TRACKBREAD
Slack in the driveline is 90% in the diff mounts and engine mounts. Adding the diff bushing inserts and subframe bushing inserts helped immensely. |
Unless you hear a clunk or sounds from under the car that shouldn't be there it should be fine. The u joints and carrier bearing are not able to be lubed so they will work fine unless you over stress the components.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
| bad driveline vibration when accelerating at low RPM | Fuergrissa | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 34 | 07-01-2019 04:49 PM |
| What driveline bushings would you replace first? | Shady195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 07-02-2015 12:57 PM |
| Driveline Defect | skoodge | Issues | Warranty | Recalls / TSB | 0 | 01-18-2013 12:16 AM |
| Cusco Driveline Components for Toyota 86 / Scion FR-S / Subaru BRZ | Speed Element | Transmission and Driveline | 8 | 01-11-2013 02:05 PM |
| The BRZ / FR-S / GT 86 transmissions and driveline: what we know so far | jruhi4 | Engine, Exhaust, Transmission | 25 | 02-17-2012 03:33 PM |
