Old 07-02-2015, 08:17 AM   #1
Shady195
Drives: '13 10 Series FRS #1203
What driveline bushings would you replace first?
I know there is a lot of info on the replacement bushings for our cars and what they accomplish but it seems all over the place in regards to what people do first.
I'm looking for a bit more responsiveness when drifting, and just an overall more positive feel when driving.
I'm trying to figure out where to start first, the rear sub frame/the diff bushings or any other bushings..
Do i need to do them all at once? I do have some concerns about stiffening up one thing only to wear out another more prematurely. Also curious if its going to make everything to loud? I'm okay with a little more noise, but i do daily drive my car and go on 3+ hour trips quite often. I udnerstand its a game of give an take when trying to balance a car that is your DD and something you want to take to the track but just trying to find that happy inbetween.
Shady195 is offline   Reply With Quote
Old 07-02-2015, 10:56 AM   #2
brillo
Drives: 2013 Firestorm FR-S
I have so far installed the rear subframe, steering rack, front LCA and transmission inert from whiteline with no material NVH increase. All of these have sharpened the steering response and eliminated alot of the slop in the rear end.
This is mostly a daily driver that I also use for HPDE events so I'm sensitive to making the car too harsh. While it is a third car, I wouldn't be concerned about a road trip with the modifications.
I'm looking into installing the avoturbo world anti tramp bushing insert for the diff to further stiffen up the driveline without all the harshness of a full bushing replacement.
curious if anyone has any NVH feedback on the avoturboworld anti tramp bushing.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-02-2015, 10:57 AM   #3
JozhGoober
Drives: 2020 718 GT4, 2013 FR-S (Turbo)
The rear subframe inserts (not the full replacement bushings) and the transmission mount insert are inexpensive and relatively easy installs, and give a much improved feel with a very minor increase in noise/vibration.
The diff inserts help a little more but gave me a fair amount more noise. I did them later, I like them but I would start with the subframe and trans inserts.
Edit: Forgot to mention, the steering rack bushings are another good improvement without any real downside.
JozhGoober is offline   Reply With Quote
Old 07-02-2015, 10:58 AM   #4
brillo
which diff insert did you use?
Old 07-02-2015, 12:34 PM   #5
JozhGoober
The Whiteline one, KDT925: http://www.whiteline.com.au/product_..._number=KDT925
Old 07-02-2015, 12:57 PM   #6
mrk1
Drives: Sterling BRZ Ltd
Rear subframe bushings are awesome, also the solid steering rack bushings.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Turn in Concepts Trans & Driveline Turn in Concepts Transmission and Driveline 4 01-10-2014 12:02 PM
replace stock swaybar bushings - any material handing differnce? brillo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-16-2013 07:15 AM
Replace shifter bushings? radroach Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 03-31-2013 10:49 AM
Driveline Defect skoodge Issues | Warranty | Recalls / TSB 0 01-18-2013 12:16 AM
The BRZ / FR-S / GT 86 transmissions and driveline: what we know so far jruhi4 Engine, Exhaust, Transmission 25 02-17-2012 03:33 PM
