Drives: 2014 FR-S
What OD resonator do I need?
Hi,
I installed a performance catback and a catless header and I'm finding there's too much drone in my car's cabin. My mechanic is telling me to order a 12 inch bottle style resonator by Vibrant. My exhaust is the Invidia gemini r400. Specs say it is a 70mm or 2.756" OD. what 12" bottle resonator do I need? I don't see a 2.75 inch x 12" Sent from my ONEPLUS A3000 using Tapatalk |
Drives: 2014 FR-S
I just spoke to Vibrant and my mechanic. This is the correct resonator for my 2.75" tubing. Vibrant does not have 2.75 but tell me (along with my mechanic) that the pipe on my car can be stretched by 1/8" to fit inside the 3" resonator because the steel itself makes up the other 1/8".
#3 | |
Drives: 2017 toyota 86
Drives: 2014 FR-S
stock front pipe. Gruppe-s over pipe and UEL header.
We are going to move the stock resonator closer to the front and put the Vibrant 1794 12" x 3" bottle resonator closer to the axle back. |
If you're putting flanges on it, you'll be fine with a 3".
Drives: 2014 FR-S
That'll work too.
#8 | |
Correct me if i am wrong but isn't the stock front pipe 2.25" and your header and catback are 2.5"-2.75"? So your smaller diameter FP is not only a bottleneck in your exhaust, it is probably what is causing most of the drone. Seems like a double res FP could fix all your problems. Just my 2 cents. |
Drives: 2014 FR-S
It's a good thought for sure, but, I want to keep my secondary cat as my header is catless. Also, the slight bottle neck is not too much of a concern as I have flashed the ECU as well and I'm quite happy with the performance. Lastly, a new front pipe with performance cat and resos only I'm told is louder. Not to mention, a lot more money than 2 hours of labour and 100 bucks for the resonator I'm adding.
#10 | |
#11 | |
Drives: 2014 FR-S
Not too worried about resale. Also, the combo of stock resonator and vibrant resonator sounds great. Sent from my ONEPLUS A3000 using Tapatalk |
#12 | |
Drives: 2014 FR-S
| What is a resonator? | WNDSRFR | Engine, Exhaust, Transmission | 10 | 02-26-2018 03:30 PM |
| dent on resonator | zizon93 | Engine Swaps | 7 | 07-08-2017 02:06 PM |
| Anyone know what this is? Resonator or cat? | Jhangles | Engine, Exhaust, Transmission | 8 | 02-21-2017 07:02 PM |
| Resonator Install | Tysoncrosby21 | Engine, Exhaust, Transmission | 8 | 01-23-2017 07:11 PM |
| Exhaust Resonator | Brndn704 | Engine, Exhaust, Transmission | 3 | 08-20-2013 02:31 PM |
