Old 07-01-2018, 11:27 AM   #1
ImRealUgly
Drives: Silver
Car Won’t Start SBD Kit W/Tune
The car has been parked for at least 4 months with the battery taken out because a pulley warped and I didn’t feel like working on it right away. I changed the fuel injectors and fuel pump (700cc injector 300 DW Pump ) got no start so I put the stock pump and injectors back on and the car still wouldn’t start. Any ideas ?
ImRealUgly is offline   Reply With Quote
Old 07-01-2018, 11:50 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Did you at least try jumping the battery? When you say it won't start, does it crank? Does it do nothing? Did you replace the warped pulley? Could be a crank position sensor or cam position sensor If you didn't get a tune for the injectors, there's a good chance it's not going to start easily/at all.
Old 07-01-2018, 01:01 PM   #3
ImRealUgly
Drives: Silver
It cranks comes on for a brief second then shuts right back off
Old 07-01-2018, 01:02 PM   #4
ImRealUgly
Drives: Silver
UPDATE: Talk to a buddy he believes I’m not getting any fuel to the injectors
Old 07-01-2018, 01:35 PM   #5
ImRealUgly
Drives: Silver
Yes the pulley was the first thing replaced
Old 07-02-2018, 02:39 AM   #6
humfrz
Are you sure the battery is good?
humfrz
Old 07-02-2018, 02:48 AM   #7
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Have you happened to mess with the DI ecu? If it's not attached or the bolts aren't properly tightened it wont get it's ground and therefore cause a no start condition
Old 07-03-2018, 05:08 AM   #8
ImRealUgly
Drives: Silver
Yea I moved the ECU back a little to have more space to work. I will try tightening it back up and see if that helps.
Old 07-03-2018, 05:09 AM   #9
ImRealUgly
Drives: Silver
humfrz
The battery is in good condition.
The Following User Says Thank You to ImRealUgly For This Useful Post:
humfrz (07-03-2018)
Old 07-03-2018, 08:39 AM   #10
ImRealUgly
Drives: Silver
Sorry for the late replies being the army and working on my car is a struggle sometimes.
humfrz (07-03-2018)
Old 07-03-2018, 12:48 PM   #11
humfrz
Thanks for serving our country ..
humfrz
Old 07-03-2018, 07:35 PM   #12
FRSBRZGT86FAN
Make sure its bolts are tightly and properly attached to that injector crash rail and its mount the way it was on the OEM has it (minus the sound tube stuff):
I circled it in red for ya
Old 07-07-2018, 11:57 AM   #13
ImRealUgly
Drives: Silver
humfrz
Thanks 👍
Old 07-07-2018, 11:59 AM   #14
ImRealUgly
Drives: Silver
Will try that tomorrow when I’m back home and give an update
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 10:04 PM
Cold start issue(tune or injectors?) 86 driver Software Tuning 0 08-01-2015 03:49 AM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 01:43 PM
Rough start but no tune.... _F-R-S_ Issues | Warranty | Recalls / TSB 27 02-26-2013 11:07 PM
Push Start Rough Engine Start Up joergasm Engine, Exhaust, Transmission 3 12-12-2012 04:44 AM
