Old 06-25-2018, 01:31 PM   #1
KDad2
KDad2's Avatar
Drives: 2013 Raven
P0420
Recently, I keep getting P0420. A few weeks back, I installed a Grimmspeed CAI, and the code came up not long afterwards. The downshifts in my '13 AT were rough, but once I cleared the code, it ran fine for about a week. Today, the code is back. I'm running catless header and OFT stage 2, V4.01 Beta. Most of the others on the forum that have had the problem was before a tune. Any suggestions besides checking that all the bolts are torqued to specs and upload the latest tune?
KDad2 is offline   Reply With Quote
Old 06-25-2018, 01:58 PM   #2
humfrz
Rexspeed hood dampers will cause that every time …
humfrz
Old 06-25-2018, 02:27 PM   #3
KDad2
KDad2's Avatar
Drives: 2013 Raven
Dang it... was hoping for some HP gains.
Old 06-25-2018, 02:49 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Your computer is stoned.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 06-25-2018, 02:54 PM   #5
KDad2
KDad2's Avatar
Drives: 2013 Raven
It needs to share with me!!!
Old 06-25-2018, 04:09 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
DTC is not disabled on the tune, hence it keeps throwing it.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-25-2018, 04:29 PM   #7
KDad2
KDad2's Avatar
Drives: 2013 Raven
Thanks, that is a lot easier fix. I'll give that a shot this evening.
Old 06-25-2018, 11:51 PM   #8
KDad2
KDad2's Avatar
Drives: 2013 Raven
I just uploaded v4.03. We'll see if that does the trick.
But, I still think there is something else going on. The same code was disabled by @steve99 and I ran with it for about 500 miles without any issues. Thanks again. I will certainly not getting rid of that file.
Anyways, could it be an issue with one of my oxygen sensors? I reused them when I replaced the header. With other cars in the past, I can read which one is bad.
Old 06-29-2018, 03:34 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
No. P0420 is Catalyst System Efficiency Below Threshold (Bank 1). If you have no cat in the manifold you will get that DTC unless it is disabled. The newer OFT tunes did not have it disabled.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-29-2018, 08:39 AM   #10
KDad2
KDad2's Avatar
Drives: 2013 Raven
Thanks. That's what I was getting too. Strange thing is that my last tune did have it disabled, and I ran it for several months, then I got the code after I installed the intake.
Tuesday, I loaded the latest version. Today, I refilled my gas tank. So, that should be at least 230 miles on it. I would think that it would of showed up by now.
p0420 Miguelgomez Issues | Warranty | Recalls / TSB 4 03-21-2018 06:59 PM
P0420 Code Miguelgomez Southeast 0 01-25-2018 09:41 PM
P0420 Code... Need help R3b00T Engine, Exhaust, Transmission 4 07-11-2016 04:18 PM
Code p0420 Patsully3 Issues | Warranty | Recalls / TSB 17 02-26-2016 10:45 PM
p0420 brichard0625 Issues | Warranty | Recalls / TSB 11 08-04-2013 09:24 PM
