Old 06-14-2018, 10:10 AM   #1
L.S.X
Drives: ft86
Talking another option for swap
recently one of my friends sent me picture of some guy that claim to have the solution for swapping engines in frs-brz-gt86 etc.
i talked with that guy he said ecumasters emu black will do the trick
then i talked with ecumasters support and they confirmed this info
so ecumasters emu black will cost 1099 for the ecu only
please excuse my english this is just to let everyone know
L.S.X is offline   Reply With Quote
Old 06-14-2018, 03:50 PM   #2
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
almost any standalone with a canbus can be programmed to control a swap. programming that canbus to control all factory aspects of the chassis is where the development comes into play
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 06-14-2018, 03:58 PM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Only has 6 ignition outputs. LS has smart coils do they not? So wouldn't work?
DustinS is offline   Reply With Quote
Old 06-14-2018, 04:02 PM   #4
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
You could run lost spark.
Old 06-15-2018, 10:18 AM   #5
L.S.X
Drives: ft86
the support guy told me they got the can bus stream for our cars
so i think you need wiring and that's all
Old 06-15-2018, 10:44 AM   #6
all4spl
hmmm I'm interested in this! I was originally looking to do emtron.
all4spl is offline   Reply With Quote
Old 06-18-2018, 03:37 PM   #7
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Every other company has failed to do complete integration so far. I had a guy tell me "Haltech said for sure it will work" guess what, it never did. I'm all for other options, but if you want everything to work in the car like factory, I wouldn't hold your breath.
Even if they have the CAN figured out, you still have to get it correctly wired and terminated in the car. As well as getting a proper engine harness, as well as having the ability to make the software work with the car, it is FAR from a couple clicks away. By the time you buy the ECU, make a jumper, buy a harness, buy all the necessary sensors and pay some poor guy to try and make 7 square pegs fit into a round hole, you'll be near the cost of a proper kit that really works.
Is it really worth risking a huge waste of your time to save a couple bucks?
Pure Automotive is offline   Reply With Quote
Old 06-20-2018, 08:27 AM   #8
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Correctly wired and terminated? You mean two wires and an internal termination resistor most all ECUs have?
I agree with the CAN data stream creation being difficult, but cmon, CAN is two wires.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 06-20-2018, 12:59 PM   #9
Pure Automotive
I'm referring more to the "plug and play" lingo that they use
Old 06-21-2018, 08:23 AM   #10
MRS-Colin
Fair. Nothing is truly plug n' play.
Colin Beck
Old 06-25-2018, 07:24 PM   #11
L.S.X
Drives: ft86
no body said anything about plug and play put this will cost 4k less than motec ecu
Old 08-14-2018, 04:21 PM   #12
Hags86
Drives: Toyota GTS 86
No. I think he's referring to the approximately 100 other wires (injectors, cam control, throttle body, sensors etc). The kits that have been sorted have a adapter harness to the OEM wiring.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
Old 08-15-2018, 07:50 AM   #13
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
I've done the research, spent hours online and on the phone. Everybody has had problems and there are inconsistencies except for MoTeC. If you try to save money and cut corners you will pay twice. Do it right the first time and just buy MoTeC!!
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Old 08-15-2018, 12:08 PM   #14
rob 2fast4u
rob 2fast4u's Avatar
Drives: 2JZ BRZ
I spent a weekend making my own harness for the 2jz with my EMU classic in my brz. all new sensors turned out to be less than 3,000$, also got a tablet dash with real dash app so it displays anything I want without buying more gauges or one could get a lcd race dash (aem, ecu master, aim,...)
rob 2fast4u is offline   Reply With Quote
Dead RB25 Swap, Alive 2jz swap -Phil Engine Swaps 72 09-15-2018 02:35 PM
Just Curious What does everyone think about the 'Hellcrate' as a swap option RedLeaderD4S Engine Swaps 5 11-08-2017 04:46 PM
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Which is the best FI option? gt8613 Forced Induction 20 01-03-2014 01:21 PM
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
