Old 06-13-2018, 01:30 AM   #1
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
NS400 bedding and questions
Hey, just picked up some ns400 locally. Noticed the box is empty besides peanut foam.
Any bedding instructions for DD and Canyon carving?
Stock caliper, rotors, 17x9 with MPSS. OEM brake fluid (changed at 33k miles, currently at 42k)
Do these have any issues w/ stock rotors?
Shim? Shimless?
Should I stick to OEM fluid or change to ATE at 60k?
Thanks!
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 06-13-2018, 12:16 PM   #2
tyler_win_photo
tyler_win_photo's Avatar
After warming up your pads a bit with a couple 30 mph to 15 mph stops, do five to ten 60 mph to 20 mph hard stops.
No issues with stock rotors.
Shimless if it does not come with any shims in the box.
A high temp fluid would be best since you're upgrading to pads with a higher temperature threshold. Not upgrading your brake fluid would be like buying wider wheels and running stretched tires, you're not realizing the full potential.
tyler_win_photo is offline   Reply With Quote
Old 06-13-2018, 01:16 PM   #3
strat61caster
strat61caster's Avatar
They're street pads, not much reason to bed them in, I never did and I'm pretty happy with mine.
ineedyourdiddly
Old 06-13-2018, 02:42 PM   #4
SmartedPanda
Thanks! Didn't see your post. Guess cuz they're just aggressive street pads there's no real bedding instructions so I'll just go with yours. Thanks! I'll get some ATE 200 next month then.
I'll be reusing the shims and I'll grab some brake grease/lube
Project Mu Brake Special - Club Racer / NS400 / G-Four 335 Speed Element Brakes, Suspension, Chassis 43 06-29-2016 03:27 PM
bedding in brake pads in GTA area FLYFISHR CANADA 13 06-04-2016 10:42 AM
Project Mu NS400 ONLY ONE SET SPECIAL PRICING! AutoRnD Brakes, Suspension, Chassis 9 08-08-2014 12:46 AM
Bedding brakes unsurety Northern California 3 06-23-2014 03:02 AM
Review: Challenge Stainless Brake Lines and Project µ NS400 pads Fenrir Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-03-2013 11:22 AM
