Old 05-06-2013, 05:57 PM   #1
Fenrir
Drives: Mazdaspeed 3
Review: Challenge Stainless Brake Lines and Project µ NS400 pads
Disclaimer: I am in no way affiliated or sponsored by Challenge or GT Motoring.
So, one of the first mods I did to my car was brakes. Few weeks after purchasing the car I had it out on the track (Autobahn South in Joliet, IL) and noticed that after a few laps the brakes turned to complete mush. A common complaint on the car for anyone who tracks it, and one of the best first mods you can do.
Here's the car as it sat before (not that there will be any noticeable outside difference after :P)
And what's going in:
With a little (read: a lot of) assistance from Austin@GTM the pads are swapped first, and then the fluid is drained:
Bracket on the new lines. Nice and solid with a rubber bushing to avoid damaging the line over prolonged use, and the lines are coated as well for further protection from any wear:
Re-uses all factory retention clips, very little issue getting it all back in:
This is the part that had me sold. A lot of line kits I see don't have this bend like the factory lines do on the rear lines. The Challenge lines have it. (top: stock lines, bottom: Challenge lines)
After all four corners, refilled with Superblue and back on the ground:
I've had them on a few months now, and they work great. Brake feel is strong and has very little fade, even after a 20 minute session on track.
The NS400's are a tad soft for my liking, but the fluid and lines keep everything very consistent. Excellent for use on a DD as they have almost no noise, but still bite pretty wicked when you get on them. Very neat products, and would highly recommend!
Willing to answer any questions to my limited abilities.
Thanks for reading!
Link to the parts used where I got them from:
Challenge Stainless Steel Lines
NS400 Front
NS400 Rear
ATE Superblue
Last edited by Fenrir; 05-07-2013 at 11:52 AM. Reason: Added bit about coating on the lines
Fenrir is offline   Reply With Quote
Old 05-06-2013, 06:00 PM   #2
oofie
Looking good!
oofie is offline   Reply With Quote
Old 05-06-2013, 06:00 PM   #3
CSG David
CSG David's Avatar
Spongy brake pedal means your fluid may have boiled. Flush it!
Old 05-06-2013, 06:08 PM   #4
Fenrir
Spongy probably isn't the right word. The pads aren't what I'm used to, as I've usually went with full track pads on my other cars. They bite pretty softly until you really stand on the pedal, and then they stop the car pretty dang quick. I'm familiar with the feeling of boiled fluid, and don't think this is quite the same. It's possible there's still a bit of air in the lines from the flush (it was almost too easy when we did it), so I'll flush them before my next event either way.
Old 05-06-2013, 06:12 PM   #5
OrbitalEllipses
Drives: Attitude
Ah, that L-fitting connection is very nice. Thus far I think only Spiegler/Essex have had that.
Old 05-06-2013, 06:22 PM   #6
Fenrir
Indeed. Fitment was identical to the factory lines. Exact same lengths right out of the box, just beefier brackets and fittings.
Old 05-06-2013, 06:25 PM   #7
OrbitalEllipses
Drives: Attitude
Pictures make it look like the line is coated; is it?
Old 05-06-2013, 06:29 PM   #8
Fenrir
Yes it is, forgot to mention that. I'll update the OP.
EDIT: Also worth pointing out that these lines come with a lifetime warranty.
Old 05-06-2013, 06:33 PM   #9
CSG David
CSG David's Avatar
Oh. That's modulation. Project Mu™
Old 05-07-2013, 10:41 AM   #10
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
Thanks for the review!
GTM_Challenge is offline   Reply With Quote
Old 05-07-2013, 10:55 AM   #11
Fenrir
I have no idea what that means but I'll assume it's good :P
Old 05-07-2013, 12:32 PM   #12
OrbitalEllipses
Drives: Attitude
Pedal modulation. As in, pressing the pedal. Modulating it. Nahmean? Some pad compounds are better at it, others aren't.
Old 05-07-2013, 01:25 PM   #13
Fenrir
I hear pedal modulation and my thought immediately is: "Vox WAH pedal?"
Old 05-07-2013, 11:28 PM   #14
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
Thanks for the review. Chase bays also have the L-fitting. They come in Black and look more like stock. Maybe good or bad, depending on what you're going for.
funbeatsfast is offline   Reply With Quote
Hawk brake pads and Goodridge stainless lines... seven Brakes, Suspension, Chassis 3 03-05-2013 08:07 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
New! Mach V stainless braided brake lines Mach V Dan Brakes, Suspension, Chassis 5 10-10-2012 12:32 PM
Stainless steel brake lines taosracer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 09-20-2012 04:09 AM
