Old 06-07-2018, 01:12 AM   #1
Eff
Drives: Toyota 86
Alignment question
Hello so I ordered MCA blue coil overs and white line LCAs
Looking to set up the car for daily driving but also want it to have abit of an aggressive stance
What would be the ideal set up to achieve this? I’ve heard some people say 1.5 degrees should be the max while having others tell me I should go 2.0 all round, what are your recommendations?
I’m also thinking about dropping the car 1/1.5” to get rid of the gap between the tires and fenders (pic related) you can also see how far the car raised up in the first photo on the left side
https://imgur.com/a/1UpLBON
Thank you in advance
Eff is offline   Reply With Quote
Old 06-07-2018, 02:08 AM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
1.5 is good enough for what you want. 2.0 is for race tracks. Unless you just want to look the part, which I assume that's all you want all show and no go. Then do 2.0 it would look the part but you'll also put more inner ware on your tires. So that's something to think about.
Old 06-07-2018, 02:14 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
From OP description poster don't want anything performance related. Drop & camber for looks. But even from looks only perspective that in turn may change, depending on wheel/tire choice, if and how much camber is needed to get what he wants.
But even if it's for looks, he should be more clear/descriptive of what exactly he wants. Flush fitment? Or if his "agressive stance" means hella-camber? Or slammed to ground? Something else?
Old 06-07-2018, 04:07 AM   #4
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I have -3.2 deg at the front, -2.7 at the rear and don't notice undue inside wear.
Yeah, set up for track but I haven't visited a track in ages.*shrugs*
Old 06-07-2018, 04:20 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
If you want to "look the part" you should get -3, -2 on stock suspension still gets outside edge wear on the track.
If you do mostly straight/highway driving any negative camber is going to wear the inside edge of your tires. But the trade off is worth it IMO
Just noticed you are running 9.5 wheels. Just do it by eye to complete the stance you are looking for then get an alignment to fix toe and match the left and right camber.
When it comes to looks and daily driving you want to set the camber to "looks good to me, doesn't rub when I drift up the KFC drive through ramp".
Set the ride height to "looks good to me, I don't pick up leaves with my front bumper, and my sub frame bolt heads don't grind on speed bumps".
Old 06-07-2018, 08:42 AM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
I run -3.4/-2.4 and don't notice wear issues. I don't daily the car, but the majority of miles are highway.
If you never carve corners, it matters less - otherwise I usually say -2 to -2.5 front, -1.8 to -2 rear.
Old 06-07-2018, 12:07 PM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
Wear issues aside (after all, camber don't eat as much tires as eg. excessive toe), grip of "track-ish" camber might be limited in winter / when rain, on loose grip surfaces like ice/snow/standing water/gravel, hence if camber isn't dictated for clearance issues of too wide wheels & tires or by some looks/stance reasons, it's better run more modest camber settings on daily driving for maximum grip.
Old 06-07-2018, 12:15 PM   #8
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Don't be afraid of running a good amount of negative camber. I always run -2.5 front and -2.0 rear and don't get any noticeable inside tire wear. It's mostly bad toe that eats tires.
smg1138 is offline   Reply With Quote
Old 06-07-2018, 12:20 PM   #9
strat61caster
strat61caster's Avatar
I started noticing inside wear issues at -4
It's the only reason my MPSS are going to just barely miss the 20k mile mark.
ineedyourdiddly
Old 06-07-2018, 02:18 PM   #10
tyler_win_photo
tyler_win_photo's Avatar
It really depends on your wheel size and offset. If you want camber for looks, you can't easily visually notice the camber until you get around -3 or more.
tyler_win_photo is offline   Reply With Quote
Old 06-07-2018, 06:35 PM   #11
Eff
Drives: Toyota 86
Thanks for the input everyone i really appreciate it because im not very familiar in the topic, i wish there was more photos online of the differnt degrees in camber for 86's so i could have a look, i think im going to try and start at -3
whats the point of making the front more cambered then the rear i see alot of people doing it?
Old 06-07-2018, 06:41 PM   #12
FirstWinter
Drives: Car
This platform uses a MacPherson strut for front suspension which loses camber under load. You'll see most guys who do AutoX, HPDE, etc run more camber up front to help with this. As for the rear the multi-link suspension gains camber under load from what I understand as well so it isn't as much of an issue. Thus why you see the common formula of more front camber than rear.
FirstWinter is offline   Reply With Quote
Old 06-07-2018, 07:01 PM   #13
Eff
Drives: Toyota 86
ahhh i see thank you, so i should probably run something like -3.5 front -3 rear?
Old 06-07-2018, 07:49 PM   #14
smg1138
smg1138's Avatar
That's probably too much in the rear. The track setups I've seen are usually around -3.5 front -2.5 rear. I would only run that much on a dedicated track car though.
Alignment Toe Question bdtbdtbdt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-24-2018 03:20 PM
Alignment question? rmar93 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-24-2018 09:28 PM
Alignment question Dee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 03-06-2018 07:55 AM
brz alignment question Shenks BRZ First-Gen (2012+) — General Topics 2 02-12-2014 09:23 PM
alignment question hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 08-15-2013 12:52 PM
