Old 06-04-2018, 11:27 AM   #1
PacManTheRS1.0
PacManTheRS1.0's Avatar
Drives: 2015 Scion FR-S Release Series 1.0
Question on Spacers
Looking at adding spacers to my RS1.0. Have a question on the OEM stud length. If I get 15mm on the front and 25mm for the rear will the studs be too long and need to be cut down?
"I am not designed to come second or third. I am designed to win." - Ayrton Senna
PacManTheRS1.0 is offline   Reply With Quote
Old 06-04-2018, 11:34 AM   #2
Harlock
Drives: 2017 BRZ
Which wheels are you using? For the 25mm, front or rear, you'll be fine. For 15mm depending on the wheel, you might have to get extended studs and use slide on 15mm vs a bolt on 15mm.
Harlock is offline   Reply With Quote
Old 06-04-2018, 11:50 AM   #3
PacManTheRS1.0
Just using stock wheels and I think the 25’s should fit fine, but was worried about the 15’s.
Old 06-18-2018, 07:45 AM   #4
PacManTheRS1.0
Update
Update: Added a backup camera, TRD decal, and the 20/25mm spacer setup this weekend. The car definitely feels even flatter through the corner and it looks more aggressive as an added bonus.
Old 06-25-2018, 05:35 PM   #5
Driven Photography
Drives: stock 15 FRS
in the picture are you using the 25's? just wanted to clarify.
Driven Photography is offline   Reply With Quote
Turn Signal Relay Question (Dumb Question) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 3 06-23-2017 01:58 AM
spacers question stock frs rims nammie81 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-05-2016 08:19 AM
wheel spacers question nammie81 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 11-16-2016 11:10 PM
FS: H&R 5mm Spacers byun Wheels and Tires 0 06-13-2016 08:03 PM
Wheel Spacers Question bhbnuckle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 04-03-2014 12:54 AM
