Old 06-02-2018, 02:27 PM   #1
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Mystery bolt
OK, so I'm a little paranoid but I found this bolt next on the floor of my garage (just swept it out yesterday) next to my drivers door after pulling my car in and out twice. It may or may not be from my car but as a long shot, if anyone might recognize it...help me find it's rightful home.
It's an M5-0.8 x 20mm and takes an m4 hex wrench. Thanks.
BirdTRD is offline   Reply With Quote
Old 06-02-2018, 02:29 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
You sure your friend below hasn't lost one?
The Following User Says Thank You to JD001 For This Useful Post:
BirdTRD (06-02-2018)
Old 06-02-2018, 04:36 PM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
If it is from the car, it's nothing important. The ridges on the side usually indicate that it's meant to be hand-tightened.
Old 06-02-2018, 04:49 PM   #4
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Your tire's tread could have picked it up from the road.
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 06-02-2018, 05:23 PM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
Yep, you're right as I have something similar on some kitchen gadgets that can be adjusted by hand.
Spuds (06-02-2018)
Old 06-02-2018, 06:48 PM   #6
wbradley
Sarcastic SOB
wbradley's Avatar
Been to Ikea?
A Chinese made oil cooler bracket or certain aftermarket parts could use those bolts but nothing I recall on the exterior of the twins.
You are paranoid or an OCD neat freak. There are probably a dozen things on the floor in my garage that could have come from my car (but didnt).
Old 06-02-2018, 07:01 PM   #7
BirdTRD
Simply Forgotus
BirdTRD's Avatar
So I was able to read the markings on the screw which indicate the manufacture (YFS) and grade (12.9). A quick google search shows this to be about equivalent to a grade 8 SAE bolt.
Looking around, I see the exact same bolt down to the MFG, grade and style (with the exception of size) on my Edelbrock SC, so that has me a little concerned.
It would be great if it was brought in by my tires but I see no indication of it going for a "ride". That's not to say it still didn't come in that way though.
Probably nothing for most normal people to worry about...but apparently I'm not normal, you might say I've been "screwed" in the past!.
Old 06-02-2018, 08:17 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
99% of socket head cap screws I have ever dealt with are ridged like that, no matter what intended use was.
I'd start checking the engine bay for comparable looking bolts. Then start looking from there.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Spuds (06-02-2018), Ultramaroon (06-03-2018)
Old 06-02-2018, 10:16 PM   #9
ZionsWrath
Thanks
ZionsWrath's Avatar
Looks like the ones on my Raceseng cascams. Mine were originally too long so they sent replacements correct length so I got loosies rolling around too
The Following User Says Thank You to ZionsWrath For This Useful Post:
Spuds (06-02-2018)
Old 06-03-2018, 07:34 AM   #10
BirdTRD
Simply Forgotus
BirdTRD's Avatar
So now I'm thinking it may have come from a bicycle I pulled from the rafters in my shed this weekend...got tired of banging my head on the handle bars and gave it away to the old guy down the street that sells bikes on the side of the road.
I'll go see if he still has it to verify that's where it came from so ya'll can stop stressing out over this little freaking screw.
The Following User Says Thank You to BirdTRD For This Useful Post:
Old 06-03-2018, 08:02 AM   #11
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
That screw looks like it's from a bottle cage or some handlebar accessory on a bike.
I have the same exact screw for my old cateye bell.
krayzie is offline   Reply With Quote
Old 06-03-2018, 05:09 PM   #12
ZionsWrath
Thanks
ZionsWrath's Avatar
What the hell, you have stuff in your garage that isn't car related????
Old 06-03-2018, 06:08 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
Hey! You asked!
Looks like a bike part. Prolly loosened from all that head-banging. Cannot recall seeing seeing SHC screws of that size on the twins.
Maybe a touch of brain trauma but not paranoid.
BirdTRD (06-03-2018)
Old 06-03-2018, 07:09 PM   #14
L8Apex
Drives: H8R FR-S
Looks exactly like the socket-head cap screw holding the hydraulic brake line bracket to the front strut on my Fortune Auto 500's. same screw also used on the camber plates in those struts. Check all those screws if you're running coilovers.
"Understeer scares the driver; oversteer scares the passenger"
L8Apex is offline   Reply With Quote
Perrin Oil Cooler - Mocal Plate Spacer Bolt - Damn Bolt Gopherboy6956 Engine, Exhaust, Transmission 16 11-23-2017 11:56 AM
Camber bolt + suspension bolt torque settings LostSalad DIY (Do-It-Yourself) Guides 3 05-09-2016 09:29 AM
mystery body kit... (no longer a mystery) Alita Cosmetic Modification (Interior/Exterior/Lighting) 3 08-16-2015 06:10 PM
my car gave birth, mystery bolt 7thgear Engine, Exhaust, Transmission 12 08-24-2012 08:02 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
