Old 08-24-2012, 04:05 PM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
my car gave birth, mystery bolt
So..
I find a bolt today underneath the engine/tranny compartment.
It’s a Subaru bolt, 14mm socket and 20mm long (so relatively short) with an "8" stamped on the head.
The bolt is pristine, no grime, oil or even water stains on it and the thread is fresh, so it wasn't bolted into anything.
So the first two questions that run through my head
1. did someone drop a spare bolt in the engine compartment after they put all lower panels on and just said fuck it
2. did someone drop a bolt that they were installing and then said fuck it after they dropped it
Now, I'm at 3000km and had some bumpy rides, along with 2 autocrosses and a track day so I'm curious why it wouldn't have freed itself earlier.. but weirder things have happened
My main concern now is how to cross refrence all the bolts that are 14mm socket and 20mm in length with an "8" stamped on them with all such bolts that are used in the engine/tranny area of the car.
Fucked up, ehh?
Old 08-24-2012, 04:06 PM   #2
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
14mm is pretty big. That would worry me.
industrial is offline   Reply With Quote
Old 08-24-2012, 04:16 PM   #3
Calum
That Guy
Drives: 2013 asphalt FRS MT
Grade 8 is an SAE standard not a metric one. For a metric bolt I would expect to see 8.8 or something similar. I don't mean to be condescending but I've gotta ask, are you sure it's not 9/16 x 3/4 inches?
Old 08-24-2012, 04:27 PM   #4
2forme
What did you name it? Just kidding. 8 is an SAE grade. You should take it to the auto parts store and use the thread display to check.
Old 08-24-2012, 04:28 PM   #5
Hix
Hix's Avatar
Drives: 2017 WRB PP
Mine gave birth to some of the larger plastic clips. Never used clips, like no scoring or anything. I checked the liner and the tray under the car and nothing looks to be missing or feels loose
Hix is offline   Reply With Quote
Old 08-24-2012, 04:52 PM   #6
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
the problem Ive found is that when you are working top side on this car and you drop something, itll get trapped between the headers and the heatshield/undertray and I cant be arsed to remove the undertray to untrap objects that fall down there.
Im sure thats what has happened in this case.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 08-24-2012, 04:59 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
Grade 8 bolts have 6 triangle marks on them, not the number 8.
Is it 8.8 on it?
Because titanium.
Old 08-24-2012, 05:02 PM   #8
ayau
Drives: Some rust bucket
i guess you'll find out if it's important or not in the next 500 miles lol.
Old 08-24-2012, 05:15 PM   #9
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Sounds exactly like a bolt that would hold the caliper bracket to the hub assembly.
I'm not saying it is, but I'd check those. Any chance you did a brake pad/rotor swap at any point?
celica73 is offline   Reply With Quote
Old 08-24-2012, 05:59 PM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
lol, no, the calipers are in place solid and i haven't touched the car at all
there is an 8 stamped on the head.. for any reference you guys can pop your hood an look at all the bolts holding various thing sin place and you'll see a few of them have 6 and some have 8 stamped on them.
Old 08-24-2012, 06:07 PM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I found a small yellow plastic clip with lots of grease on it ..
Been meaning to find out where the heck it came from :/
Old 08-24-2012, 06:31 PM   #12
celica73
Might still check the bolts - they fit your description pretty well. It could also be something that holds an accessory bracket onto the engine block (AC, alternator, etc), or a motor/transmission mount.
Old 08-24-2012, 08:02 PM   #13
so26
Drives: Raven FR-S 6MT
Did you have your oil changed recently? It sounds about the same size as the oil pan plug.
so26 is offline   Reply With Quote
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
Just gave up my WRB Limited 6MT 3/14 (7 of 16)preorder in Chicago n7011n BRZ First-Gen (2012+) — General Topics 6 06-19-2012 10:48 PM
FR-S SNS 200 mystery NAV/XM/Receiver FR-S-Ohio Electronics | Audio | NAV | Infotainment 2 05-31-2012 06:58 AM
Obama Birth Certificate Maybe Forged, Sheriff Joe Arpaio Says vh_supra26 Off-Topic Lounge [WARNING: NO POLITICS] 16 03-05-2012 02:38 PM
if i gave you 25k to buy a car andygee Off-Topic Lounge [WARNING: NO POLITICS] 47 04-17-2011 10:52 PM
