Anyone have Atoto A6 Bluetooth working?
I just installed an Atoto A6 Android head unit in my BRZ. It’s a nice unit, but I can’t get the Bluetooth to work with either the PLX Kiwi 3 ODB adapter or the Sky Pro xgps160 10 Hz GPS. Has anyone gotten this to work?
The Kiwi 3 pairs, but none of the apps I tried can read from it, and it doesn’t even see the xgps160. Both devices are alleged to work with Android. |
Drives: 2017 86
How are you liking this head unit? And how was the install? I'm thinking of purchasing the same one. I have the same GPS Unit i use with solostrom. But wasn't planning on using solostorm with this unit because none of the headunits i've found come with an accelerometer.
#3 | |
#4 | |
What really sold it was the Toyota specific model that fit my dash. I have a 2013 BRZ and I added the 1 piece dash when I installed. All I had to do was pop the plastic frame off the 1 piece dash and it fits flush. No ugly brackets! It also came with a plug and play harness that worked 90% out of the box. To get it to work 100% I had to connect the blue and white wire on the HU's harness to the brown wire located at pin 9 in my car's 10 pin connector. (That last bit is for anyone one who found this via the search function because their door speakers wouldn't work after install, I searched for a while to get clear info on that) Is it the snappiest head unit? No but its way better than stock. Does it have amazing sound? To me it sounds great, better than stock but if you are doing a real audio build you probably have different standards than I do. All and all I'd say at $259 for the 2gb model its a great buy. |
| The Following 2 Users Say Thank You to _search For This Useful Post: | invaliduser (07-12-2018), XtremeMaC (05-07-2019) |
Drives: 2017 86
I really appreciate the feedback. Thank you!
#6 | |
The Fail Boat
Drives: CWP S.B.
is it gonna fit the old trim piece on your 2013? (*2 piece one) :O Sorry just started researching on these. |
It is going to be tight but it might, I believe the opening on the stock trim piece is 200mm wide and Atoto lists this head unit as 205mm wide. Being that the one piece dash is a leather-ish material it has a but more give to it than the plastic. However I think maybe with a little sanding or dremeling you can get an extra 2.5mm on each side.
Drives: 1999 Miata
Mine fit fine once the brackets were mounted in the correct locations. The Atoto A6 is 205mm wide at the widest spot, but were the corners are rounded and it meets the face plate it is 200mm x 100mm.
I posted a picture in this thread: http://www.ft86club.com/forums/showthread.php?t=129106
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
| The Following User Says Thank You to MX-5RACER For This Useful Post: | XtremeMaC (05-07-2019) |
#9 | |
| I need help with bluetooth | tmcmullins | Electronics | Audio | NAV | Infotainment | 10 | 07-06-2013 12:21 AM |
| Bluetooth Mic | DatDudeLoso | Electronics | Audio | NAV | Infotainment | 4 | 01-17-2013 08:51 PM |
| Bluetooth | grgonium | CANADA | 22 | 10-24-2012 12:52 AM |
| Bluetooth/Nav | inimitable | Electronics | Audio | NAV | Infotainment | 40 | 09-26-2012 08:35 PM |
| FRS bluetooth set up | jym89709 | Electronics | Audio | NAV | Infotainment | 16 | 09-08-2012 03:04 PM |
