Old 05-26-2018, 06:42 PM   #1
Adamf220
Drives: 2013 frs
2016 brz radio in 2013 frs no door speakers
So I recently got a 2016 brz clarion radio for my 2013 frs. My cars stock radio was not a touch screen. Installed it and I have no sound from my door speakers. Everything connected fine besides the USB AUX cord hook up, which apparently doesn't connect to it. Can't seem to find the reason, thought the pins where the same but the one for the amp must be different any information would be great. Also looks like I'm gonna have to take a Dremel to the trim piece to make it fit. Also got a killer deal on it and it's a major upgrade from my pos non touch screen so not really looking to go aftermarket. Don't care about nav either.
Adamf220 is offline   Reply With Quote
Old 05-27-2018, 09:57 PM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Pin 9 on the 28 pin radio connector is the amp turn on for a 2016 BRZ... so you would need to connect that to the proper wire for a 2013 frs for the door speakers to work. Based on what I’ve read, the amp turn on in a 13 FRS would be pin 9 on the 10 pin connector. http://www.ft86club.com/forums/attac...4&d=1340370296
NCtoBRZ is offline   Reply With Quote
Old 05-30-2018, 10:04 AM   #3
Adamf220
Drives: 2013 frs
Thanks that is very helpful
Old 05-30-2018, 02:22 PM   #4
Adamf220
Drives: 2013 frs
So ive tried to find a new female pin so i can just rewire it but it looks to be hard to fine. I was wondering if you or anyone knows if i can connect it to another 12v line and just piggy back off that?
Old 05-30-2018, 10:23 PM   #5
NCtoBRZ
Any switched 12 volt source connected to pin 9 on the 10 pin connector should do the trick I would think.
2016 brz premium steering wheel, radio, door panels, rear seat belts/ seat brackets. Joesurf79 Interior Parts (Incl. Lighting) 12 06-01-2018 11:51 PM
FS: 2013 Scion FRS upgraded Pioneer Radio, door speakers, amp Takumi788 Audio/Visual, Electronics, Infotainment, NAV 8 08-23-2017 09:29 AM
2013 BRZ OEM Amplifier + Door Speakers (SE MI area only) kberkel Audio/Visual, Electronics, Infotainment, NAV 2 08-20-2016 03:24 AM
Amp, Radio, Sub, Speakers, va Fr-s13 Audio/Visual, Electronics, Infotainment, NAV 2 06-10-2013 04:45 PM
Help:new aftermarket radio and question regarding speakers FR-Shadow Electronics | Audio | NAV | Infotainment 2 11-04-2012 07:58 PM
