Old 05-24-2018, 02:30 PM   #1
JohnnyGT86
JohnnyGT86's Avatar
Drives: 2014 FRS
17x8 +30
17x8 +30 offset will it fit well paired with 235 or 245's?
JohnnyGT86 is offline   Reply With Quote
Old 05-24-2018, 02:37 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Are you lowered? 17x8 +30 is slightly aggressive. 235/45 is too tall of a tire. 235/40 is a rare size but could work. And 245/40 is to wide for a 17x8 IMO, so I would suggest a 225/45/17 with front camber bolts set at -1.5. Rears will be flush.
I LIKE TIRES!
The Following 2 Users Say Thank You to Leonardo For This Useful Post:
jordan7831 (05-24-2018), wparsons (05-24-2018)
Old 05-24-2018, 02:52 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
17x9 +40 would be a better wheel size/offset to run 235/40- or 245/40-17...
Leonardo (05-24-2018)
Old 05-24-2018, 10:27 PM   #4
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
245/40 on a 17x8 is fine but I wouldn't recommend going any wider. Here is a pic of my 245/40r17 on my 17x8 +35 wheels.
If you were running 17x8+30, you'd have pretty close to similar poke as a 17x9+35 so you may want to run a bit of front end camber to tuck the tire in a bit.
Lynxis is offline   Reply With Quote
The Following User Says Thank You to Lynxis For This Useful Post:
sato (09-21-2022)
Old 05-24-2018, 10:41 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I have run 245 on an 8", and I do not recomend it. 225 max IMO.
17x9 +42 has similar poke to 17x8 +30.
I LIKE TIRES!
rvoll (05-25-2018), sato (09-21-2022)
Old 05-24-2018, 10:51 PM   #6
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
225/45 17 is the most ideal tire i would run on a stock motor 86 and most ideal on 17x8
DuMa is offline   Reply With Quote
The Following 4 Users Say Thank You to DuMa For This Useful Post:
Leonardo (05-24-2018), rvoll (05-25-2018), sato (09-21-2022), wparsons (05-25-2018)
ESM 17x8.5 yutinggao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-16-2016 12:17 PM
17x8 all around or staggered 17x8 & 17x9 cawith Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-12-2015 12:27 PM
245-40-17 on 17x8 +35??? Fast_Freddy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 11-27-2013 02:49 AM
Will a 17x8.5 +15 fit? Drftfan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-08-2013 07:11 PM
XXR 527 17x8.25 +35(front) 17x8.25 +25(rear) and 1 inch drop AGM6789 AUSTRALIA 17 11-10-2012 05:10 AM
